PSA Electrical Diagrams - List of Components 2300 to 6579
x 6948
From 2300 To 5016From 5020 To 6579
2300: Hazard Warning Switch.5105: Heated Windscreen Wash Jets.
2305: Flasher Unit.5110: Wash Liquid Level Sensor.
2310: Direction Indicator Switch.5115: Front/Rear Screen Wash Pump.
2320: Left-Hand Front Direction Indicator Lamp.5200: Tailgate Wipe/Wash Control (If Separated).
2325: Right-Hand Front Direction Indicator Lamp.5202: Rear Screen Wiper Switch.
2330: Left-Hand Rear Direction Indicator Lamp (If Separated).5203: Rear Screen Wash Switch.
2335: Right-Hand Rear Direction Indicator Lamp (If Separated).5204: Rear Wiper Motor Contact (If Separated).
2340: Left-Hand Side Repeater Flasher.5205: Tailgate Wiper Relay.
2345: Right-Hand Side Repeater Flasher.5210: Rear Screen Wiper Timer.
2400: Sidelamp Day Running Lights Line Relay.5211: Left Hand Rear Screen Wiper Motor.
2401: Dipped Beam Day Running Lights Relay.5212: Right Hand Rear Screen Wiper Motor.
2402: Daylight Running Lights Relay Shunt.5215: Rear Screen Wiper Motor.
2410: Dipped Beam Relay.5300: Rear Screen Wash Pump.
2411: Dim-Dip Relay.5400: Headlamp Wash Timer Relay.
2415: Dim-Dip Resistor.5401: Headlamp Wash Relay.
2500: Horn Button.5405: Headlamp Wash Pump.
2501: Horn Button In Steering Wheel.5406: Headlamp Wash Switch.
2505: Air Horn Compressor Relay.6000: Left-Hand Door Left-Hand Window Lift Switch.
2510: Air Horn Compressor.6001: Left-Hand Window Lift Front Switch.
2520: Horns.6002: Right-Hand Window Lift Front Switch.
2521: Low Note Horn.6005: Right-Hand Door Right-Hand Window Lift Switch.
2522: High Note Horn.6010: Right-Hand Door Left-Hand Window Lift Switch.
2523: Pedestrian Buzzer.6015: Left-Hand Door Right-Hand Window Lift Switch.
2525: Air Horn Fuse.6016: Window Lift Circuit Diode + Sun Roof.
2530: Siren Unit (Police).6020: Front Window Lift + Sun Roof Relay.
2531: Police Siren Switch.6021: Window Lift Relay.
2532: Day/Night Police Siren Switch.6025: Window Lift + Sun Roof Supply Re-Connection Relay.
2535: Siren Speaker (Police).6029: Driver's Door One-Touch/ Safety Auto-Reverse ECU.
2600: Lamp Rotator.6030: One Touch Electric Window Control Unit.
2605: Dipped Beam Relay.6031: Passenger's One Touch Front Electric Window Motor + Control Unit.
2606: Main Beam Relay.6032: Driver's One Touch Front Electric Window Motor + Control Unit.
2610: Left-Hand Headlamp.6033: Safety Auto-Reverse Control Unit.
2615: Right-Hand Headlamp.6034: Safety Auto-Reverse Sensor.
2620: Front Left Side Light.6035: Safety Auto-Reverse Window Motor (Driver's Door).
2625: Front Right Side Light.6036: Window Lift Control Board/ Rear-View Mirror (Driver's Door).
2630: Left-Hand Tail Lamp.6037: Window Lift Control Board/ Rear-View Mirror (Passenger Door).
2631: Right-Hand Tail Lamp On Boot Lid.6038: Safety Auto-Reverse Window Motor (Passenger Door).
2632: Left-Hand Tail Lamp On Boot Lid.6040: Window Lift Motor (Front LH).
2633: Number Plate Right-Hand Lamp.6041: Interior Handle Sensor (Driver's Door).
2634: Jack Socket Shunt.6042: Exterior Handle Sensor (Driver's Door).
2635: Right-Hand Tail Lamp.6043: Interior Handle Sensor (Passenger Door).
2636: Number Plate Lamp.6044: Exterior Handle Sensor (Passenger Door).
2637: Jack Plug For Rotating Lamp.6045: Window Lift Motor (Front RH).
2638: Rotating Lamp.6100: Left-Hand Rear Window Lift Rear Switch.
2639: Rotating Lamp Switch.6101: Right Rear Window Lift Unit + Motor (One-Touch).
2640: Left-Hand Front Door Marker Lamp.6102: Left Rear Window Lift Unit + Motor (One-Touch).
2641: Front Right Side Marker.6105: Right-Hand Rear Window Lift Rear Switch.
2642: Front Left Side Marker.6110: Left-Hand Rear Window Lift Front Switch.
2643: Rear Right Side Marker.6115: Right-Hand Rear Window Lift Front Switch.
2644: Rear Left Side Marker.6116: Rear Electric Window Control Panel.
2645: Right-Hand Front Door Marker Lamp.6120: Rear Window Lift Inhibitor Switch.
2650: Left-Hand Rear Door Marker Lamp.6121: Rear Function Locking Relay.
2651: Police Car Bar Across Roof.6122: Rear Window Lift Inhibitor Switch + Alarm Cut-Off.
2655: Right-Hand Rear Door Marker Lamp.6125: Rear Window Lift Relay.
2656: Rear Facing Flashing Stop Lights.6126: Rear Window Lift Relay On + Aa.
2657: Rear Facing Flashing Stop Lights Central Unit (Roof Tail Lamps).6130: Window Lift Motor (Rear LH).
2658: Rear Roof Lamp Switch.6131: Right Rear Window Lift Unit + Motor.
2659: Orange Lights Switch.6132: Left Rear Window Lift Unit + Motor.
2660: Front Fog Lamp Switch.6133: Safety Auto-Reverse Window Motor (Rear Left-Hand Door).
2662: Front Fog Lamp Inhibitor Relay (Front).6134: Safety Auto-Reverse Window Motor (Rear Right-Hand Door).
2665: Front Fog Lamp Relay.6135: Window Lift Motor (Rear RH).
2670: Left-Hand Front Fog Lamp.6140: Rear Window Lift Relay 4- Heated Seat.
2675: Right-Hand Front Fog Lamp.6200: Front Left-Hand Door Open Switch.
2680: Long Range Driving Lamp Switch.6202: Driver's Door Lock Assembly.
2685: Long Range Driving Lamp Relay.6203: Switch Insulation Diode (Front Door/Rear).
2690: Left Hand Long Range Driving Lamp.6204: Rear Wiper Motor Contact (If Separated).
2695: Right Hand Long Range Driving Lamp.6205: Front Right-Hand Door Open Switch.
3000: Left Hand Front Door Flange Switch.6207: Front Passenger Door Lock Assembly.
3001: Right Hand Front Door Flange Switch.6210: Rear Left-Hand Door Open Switch.
3002: Door Aperture Switch-Rear Left-Hand Door.6212: Rear Left-Hand Door Lock Assembly.
3003: Door Aperture Switch-Rear Right-Hand Door.6215: Rear Right-Hand Door Open Switch.
3004: Lighting Timer Unit.6216: Boot Lid Open Switch.
3005: Courtesy Lamp Timer Relay.6217: Rear Right-Hand Door Lock Assembly.
3006: Courtesy Lamp Switch.6218: Right-Hand Rear Hinged Door-Lock Assembly.
3010: Front Courtesy Lamp.6219: Door Unlocking Safety Relay.
3012: Courtesy Lamp (Front LH).6220: Door Locking Switch.
3013: Courtesy Lamp (Front RH).6221: Right-Hand Rear Hinged Door Locking Switch.
3015: Roof Console + Integral Functions.6222: Boot Lock Assembly.
3019: Rear Courtesy Lamp Switch.6230: Infra Red Door Locking Receiver.
3020: Rear Courtesy Lamp.6231: High Frequency Receiver For Central Locking.
3022: Rear Left-Hand Courtesy Lamp.6235: Central Locking Control Unit.
3023: Rear Right Hand Courtesy Lamp.6237: Boot Unlocking Switch.
3024: Left-Hand Courtesy Lamp.6240: Left-Hand Front Door Lock Motor.
3025: Right-Hand Courtesy Lamp.6242: Front Left-Hand Door Deadlock Motor.
3029: Centre Courtesy Lamp Switch.6245: Right-Hand Front Door Lock Motor.
3030: Central Courtesy Lamp.6247: Front Right-Hand Door Deadlock Motor.
3031: Front Right-Hand Reading Lamp.6250: Left-Hand Rear Door Lock Motor.
3032: Front Left-Hand Reading Lamp.6252: Rear Left-Hand Door Deadlock Motor.
3033: Rear Right-Hand Reading Lamp.6253; Left-Hand Rear Hinged Door Locking Motor.
3034: Rear Left-Hand Reading Lamp.6255: Right-Hand Rear Door Lock Motor.
3035: Footwell Illumination.6256: Rear Door Lock Motor.
3036: Right Hand Footwell Light.6257: Rear Right-Hand Door Deadlock Motor.
3037: Left Hand Footwell Light.6258: Right-Hand Rear Hinged Door Locking Motor.
3040: Left-Hand Front Door Tread Lamp.6259: Right-Hand Rear Hinged Door Deadlocking Motor.
3042: Left-Hand Rear Door Tread Lamp.6260: Boot Or Tailgate Lock Motor.
3045: Right-Hand Front Door Tread Lamp.6261: Tailgate Locking Motor.
3047: Right-Hand Rear Door Tread Lamp.6262: Luggage Compartment Deadlocking Motor Diode.
3050: Lighting Rheostat.6265: Fuel Filler Flap Lock Motor.
3051: Heater Control Panel Lamp.6266: Charging Flap Locking Motor.
3052: Console Lamp.6282 : Boot Opening Switch
3053: Cigar Lighter Lamp.6283 : Tailgate Opening Switch
3054: Ashtray Lamp.6289 : Boot Striker Plate
3055: Radio Cover Control Lamp.6290 : Boot Manoeuvring Unit
3056: Ashtray Cover Control Lamp.6292 : Boot Switch
3057: Left-Hand Vent Lighting.6295 : Setting Of Rear Zone 1
3058: Right-Hand Vent Lighting.6296 : This Is A Stored Input
3059: Centre Vent Lighting.6300: Driver's Seat Sliding Switch.
3060: Vanity Mirror Lamp (On The Driver's Side).6301: Control Unit For Memorising Seat And Mirror Positions.
3061: Vanity Mirror Lamp (Passenger's Side).6302: Driver's Seat Adjustment Assembly.
3062: Rear Ashtray Lighting.6303: Passenger's Seat Adjustment Assembly.
3065: Map Reading Lamp.6304: Seat Position Memory ECU (Passenger).
3070: Selector Lever Lamp.6305: Passenger's Seat Sliding Switch.
3075: Ignition Switch Lamp.6307: Keypad For Memorising Seat Position.
3080: Police Visor Lamp.6308: Presence Sensor.
3085: Central Passenger Courtesy Light Switch (White Light).6310: Driver's Seat Raising Switch.
3086: Central Passenger Courtesy Light Switch (Blue Light).6311: Switch : Driver's Seat Front Cushion.
3087: Parking Lamps Switch.6312: Switch : Driver's Seat Rear Cushion.
3088: Parking Lamps Relay.6315: Passenger's Seat Raising Switch.
3100: Luggage Compartment Switch.6320: Driver's Seat Slide Motor.
3105: Boot (Or Luggage Compartment) Lamp.6321: Slide Position Sensor (Driver's Seat).
3106: Luggage Compartment Left-Hand Lighting.6322: Height Adjustment Motor (Driver's Seat).
3107: Luggage Compartment Right-Hand Lighting.6323: Height Adjustment Motor (Passenger's Seat).
3110: Glove Box Lamp Switch.6325: Passenger's Seat Slide Motor.
3115: Glove Box Lamp.6331: Driver's Seat Height Position Sensor.
3120: Bonnet Switch.6332: Driver's Seat Cushion Front Height Motor.
3121: Engine Compartment Lamp.6333: Driver's Seat Front Cushion Position Sensor.
3122: Engine Compartment Lamp Switch.6334: Driver's Seat Cushion Rear Height Motor.
3125: Luggage Compartment Lamp Relay.6335: Driver's Seat Rear Cushion Position Sensor.
3126: Luggage Compartment Light Timer Relay.6337: Passenger's Seat Cushion Front Height Motor.
0004: Instrument Panel.6339: Passenger's Seat Cushion Rear Height Motor.
4000: Instrument Panel Centralised Electronic Module.6340: Driver's Seat Backrest Switch.
4005: Coolant Temperature Sensor.6341: Seatback Position Sensor (Driver's Seat).
4010: Engine Coolant Level Switch.6345: Passenger's Seat Backrest Switch.
4015: Engine Coolant Level Unit.6346: Centre Armrest Switch.
4020: Engine Coolant Thermal Switch.6347: Centre Armrest Motor.
4025: Temperature Sensor - Engine Coolant Thermal Switch (Gauge).6350: Driver's Seat Backrest Inclination Motor.
4026: Coolant Temperature Gauge.6355: Passenger's Seat Backrest Inclination Motor.
4030: Coolant Thermistor (Gauge).6360: Driver's Seat Adjustment Relay.
4035: Pre-Warning Heat Switch.6365: Passenger's Seat Adjustment Relay.
4040: Coolant And Air Conditioning Thermistor.6366: Slide High Speed Motor - Passenger's Seat.
4050: Water In Fuel Sensor.6367: Slide High Speed Motor - Driver's Seat.
4060: Battery Charge Indicator.6370: Adjustment Pump + Solenoid Valve Assembly - Driver's Seat.
4100: Temperature Gauge + Engine Oil Level.6371: Passenger's Seat Backrest Inflation Contact.
4101: Engine Oil Temperature Display.6372: Driver's Seat Backrest Inflation Contact.
4102: Engine Oil Level Gauge.6373: Driver's Seat Front Stop Position Micro Switch.
4103: Temperature Sensor (Engine Oil).6374: Seat Back Locked Position Micro Switch -Driver's Seat.
4104: Engine Oil Pressure Sensor.6375: Adjustment Pump + Solenoid Valve Assembly - Passenger's Seat.
4105: Engine Oil Pressure Gauge.6376: Passenger's Seat Front Stop Position Micro Switch.
4106: Pressure Sensor/Oil Pressure Switch.6377: Seat Back Folded Position Micro Switch -Passenger's Seat.
4110: Oil Pressure Switch.6378: Seat Back Locked Position Micro Switch -Passenger's Seat.
4111: Temperature Sensor + Engine Oil Thermal Switch.6379: Passenger's Seat Memorised Position Micro Switch.
4120: Engine Oil Level Sensor.6380: Rear Seat Cushion Adjustment Switch.
4130: Engine Oil Thermal Switch.6381: Rear Seat Adjustment Motor.
4200: Choke Switch.6382: Seat Adjustment Switch (Rear RH).
4205: Air Cleaner Pressure Switch.6383: Seat Adjustment Switch (Rear LH).
4210: Tachometer (If Separated).6384: Seat Adjustment Motor (Rear RH).
4240: Induction Pressure Sensor.6385: Seat Adjustment Motor (Rear LH).
4241: Turbocharge Pressure Gauge.6386: Rear Head-Rest Retracting Switch (Right Side).
4300: Low Fuel Level Switch.6387: Rear Head-Rest Retracting Switch (Left Side).
4310: Fuel Gauge.6388: Head-Rest Motor (Rear RH).
4311: Fuel Pump Electronic Damping Unit.6389: Head-Rest Motor (Rear LH).
4315: Fuel Gauge (Transmitter).6390: Rear Head-Rest Retracting Switch.
4320: Tank Cap Present Switch.6391: Seat Adjustment Assembly (Rear RH).
4330: Fuel Flow Meter (Trip Computer).6392: Seat Adjustment Assembly (Rear LH).
4335: Fuel Consumption Interface Unit.6400: Driver's Side Rear View Mirror Control.
4340: Fuel Consumption.6405: Passenger's Side Rear View Mirror Control.
4341: Current Fuel Consumption Indicator.6406: Rear View Mirror Control.
4400: Handbrake Switch.6407: Fold Back Rear View Mirror Unit.
4401: Parking Brake Warning Lamp Diode.6410: Driver's Side Rear View Mirror (Electric Mirror/Heated Mirror).
4402: Reverse Gear Buzzer Diode.6415: Passenger's Side Rear View Mirror (Electric Mirror/Heated Mirror).
4405: Vacuum Pressure Switch Control Of The Brake Servo Vacuum.6420: Fold-Back Mirror Switch.
4410: Brake Fluid Level Switch.6421: Reverse Indexing Unit.
4420: ABS Warning Lamp Relay.6422: Reverse Indexing Switch.
4430: Front Left Brake Pad Wear Contact.6430: Electric Interior Mirror.
4431: Front Right Brake Pad Wear Contact.6435: Anti-Dazzle Unit.
4432: Rear Left Brake Pad Wear Contact.6440: Electrochrome Interior Mirror.
4433: Rear Right Brake Pad Wear Contact.6470: Steering Wheel Adjustment Switch.
4440: Bulb Failure Detection Control Unit.6471: Steering Wheel Height Adjustment Motor.
4445: Blown Bulb Relay (Warning Lamp).6472: Steering Wheel Depth Adjustment Motor.
4450: Brake Warning Lamp Relay (Australia).6500: Driver's Passive Restraint Switch.
4500: Ride Height Correction Fluid Level Switch.6505: Passenger's Passive Restraint Switch.
4605: Selection Or Programme Display.6510: Driver's Passive Restraint Control Unit.
4610: Gearbox Oil Thermal Switch.6515: Passenger's Passive Restraint Control Unit.
4630: Speedometer.6520: Passive Restraint Time Switch Relay.
4635: Tachograph Electronic Converter.6530: Driver's Passive Restraint Motor.
4700: Left-Hand Front Door Lock Switch (Door Open Detection) (If Different 3000).6535: Passenger's Passive Restraint Motor.
4701: Right-Hand Front Door Lock Switch (Door Open Detection) (If Different 3001).6540: Driver's Pre-Tensioning Seat Belt Control Unit.
4702: Left-Hand Rear Door Lock Switch (Door Open Detection) (If Different 3002).6541: Passenger's Pre-Tensioning Seat Belt Control Unit.
4703: Right-Hand Rear Door Lock Switch (Door Open Detection) (If Different 3003).6542: Pre-Tensioning Seat Belt Control Unit.
4704: Bonnet Closed Switch (Bonnet Open Detection).6543: Passenger Presence Detector.
4705: Boot Lock Switch (Boot Open Detection).6544: Presence Detector (Rear RH).
4710: Headlamp Flash Relay.6545: Presence Detector (Rear LH).
4715: Door Open Buzzer.6546: Presence Of Passenger Detection Unit.
4716: Parking Brake Position Reminder Buzzer.6551: Right-Hand Side Air Bag Screen Module.
4720: Lamps On Buzzer Relay.6552: Left-Hand Side Air Bag Screen Module.
4725: Lamps On + Ignition Key In Buzzer Relay.6553: Air Bag Shunt Resistor.
4730: Seat Belt Switch.6554: Front Top Left-Hand Side Air Bag Module.
4735: Seat Belt Buzzer Relay.6555: Front Top Right-Hand Side Air Bag Module.
4740: Overspeeding Buzzer.6556: Rear Bottom Left-Hand Side Air Bag Module.
4750: Anti-Lock Braking Buzzer Relay.6557: Rear Bottom Right-Hand Side Air Bag Module.
4760: Ignition Key In Lock Switch (Buzzer Control).6558: Rear Top Right-Hand Side Air Bag Module.
4765: Ignition Key In Lock Buzzer Relay.6559: Rear Top Left-Hand Side Air Bag Module.
4790: Electric Motor Reminder Buzzer.6560: Airbag ECU.
4800: Catalytic Converter Temperature Sensor.6561: Air Bag Control Unit Auto Interference Suppression.
4805: Catalytic Converter Temperature Control Unit.6562: Front Bottom Right-Hand Side Air Bag Module.
4900: Door Open Indicator Display.6563: Front Bottom Left-Hand Side Air Bag Module.
4905: Points Matrix.6564: Passenger's Air Bag Module.
4990: Charging Flap Open Check Contact.6565: Driver's Air Bag Module.
0005: Screen Wiper Switch.6566: Airbag Light Relay.
5000: Windscreen Wipe/Wash Switch (If Separated).6567: Right-Hand Impact Detector.
5001: Rain Sensor.6568: Left-Hand Impact Detector.
5002: Rain Sensor Control Relay.6569: Passenger Air Bag Neutralisation Switch.
5003: Rain Sensor Speed Control Relay.6570: Air Bag And Pre-Tensioners Control Unit.
5004: Automatic Windscreen Wiper Control Unit.6571: Side Airbag Unit (Right).
5005: Windscreen Wiper Relay.6572: Side Airbag Unit (Left).
5006: Front/Rear Wiper Relay.6573: Driver's Lateral Satellite.
5010: Windscreen Wiper Timer.6574: Passenger's Lateral Satellite.
5015: Windscreen Wiper Motor.6575: Pre-Tensioning Seat-Belt (On The Driver's Side).
5016: Parking Stop Unit.6576: Pre-Tensioning Seat-Belt (Passenger's Side).
5020: Wash Fluid Heater.6577: Pre-Tensioner (Rear LH).
5021: Pipe Heater.6578: Pre-Tensioner (Rear RH).
5100: Windscreen Wash Pump.6579: Central Rear Pre-Tensioner.
