Coolant system bleed sequence?
Dazzler_75
Unread post by Dazzler_75 »
Hi, new member here. I have a 2016 C4 GP 2.0 blue Hdi. Looks like I have a blocked heater matrix. System is split heating/aircon. Passenger side hot when set to hi, drivers side is relatively cool in comparison. Not too bad a job it appears but I've read there is a particular way to bleed the cooling system correctly. Is there anyway I can access this? Cant find much online and on here it says I cant view it (was a link on another thread here about this)
Thanks 😊
x 6963
Re: Coolant system bleed sequence?
The Resources section is for donating members, details below:
A response to your question by a Forum Admin requiring parts or additional information requires you to have made a current contribution (£10 min.) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
PaulC5
x 654
Unread post by PaulC5 »
Rather than a blocked heater matrix, it is more likely a warm air flap problem if you have climate control . Could be a flap motor fault or a stuck flap or even flap damage. Also make sure the pollen filter is clean so not restricting the air flow.
x 1475
Blocked matrix on Mk2 Picasso is very common. It is at least easy to change.
