Hi all,
This is my first post so apologies if i'm in the wrong area.
My 407 SW Sport 140 HP has a cooling fan loom that has a 4 pin connector behind the front bumper. Just purchased a replacement from euspares but the fan has a 3 pin connector. Everything else is the same. All the fans I have looked at have 3 pin connectors. Is it because I have a sport?
Any help will be much appreciated.
Brgds
Allan
Peugeot 407 SW 2.0 Sport Cooling Fan
- x 6957
Re: Peugeot 407 SW 2.0 Sport Cooling Fan
You may have the incorrect fan in that case. That's the problem with aftermarket parts - they are often incorrect.
It depends on your vehicle as some have a 2 pin connector AND a 3 pin connector.
If you need an original, genuine part number, and can't already find the info you need on the Forum, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below, then pop your VIN up.
jonpearce
Did you get anywhere with this?
I've got exactly the same issue with my 59 plate 1.6 HDi. Can't find the 4 pin version of the fan anywhere, new or used.
JorgeRP
Good evening.
My name is Jorge, and I'm from Madrid, Spain. It's a pleasure to greet you.
I'm having the same problem with the 4-pin fan. Were you able to resolve it?
If so, please let me know how you did it.
Thank you very much.
