Peugeot 407 SW 2.0 Sport Cooling Fan
senlacas
Unread post by senlacas »
Hi all,
This is my first post so apologies if i'm in the wrong area.
My 407 SW Sport 140 HP has a cooling fan loom that has a 4 pin connector behind the front bumper. Just purchased a replacement from euspares but the fan has a 3 pin connector. Everything else is the same. All the fans I have looked at have 3 pin connectors. Is it because I have a sport?
Any help will be much appreciated.
Brgds
Allan
x 6963
Re: Peugeot 407 SW 2.0 Sport Cooling Fan
You may have the incorrect fan in that case. That's the problem with aftermarket parts - they are often incorrect.
It depends on your vehicle as some have a 2 pin connector AND a 3 pin connector.
If you need an original, genuine part number, and can't already find the info you need on the Forum, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below, then pop your VIN up.
A response to your question by a Forum Admin requiring parts or additional information requires you to have made a current contribution (£10 min.) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
jonpearce
Unread post by jonpearce »
Did you get anywhere with this?
I've got exactly the same issue with my 59 plate 1.6 HDi. Can't find the 4 pin version of the fan anywhere, new or used.
JorgeRP
Unread post by JorgeRP »
Good evening.
My name is Jorge, and I'm from Madrid, Spain. It's a pleasure to greet you.
I'm having the same problem with the 4-pin fan. Were you able to resolve it?
If so, please let me know how you did it.
Thank you very much.
