Hey! I was wondering if someone could help please as I'm needing to drain my 2015 308 adblue tank but can't find anywhere to say how. Any ideas please?
Many thanks Alex xx
How to drain 2015 308 AdBlue tank
- x 1056
Re: How to drain 2015 308 AdBlue tank
There is a little drain plug on the bottom of the tank (number 5 in the picture)
There is a little torx screw (T-20 from memory) holding the plug in, once you undo this just twit the plug & pull.
Leave the filler cap on initially to make it empty more controlled, Just be ready if you have the filler cap removed it drains out fast.
grazelgirl
Thank you so much!! You're a hero!! Xx
Tibbs1994
- New User
Hi
Thanks for this,
I have a 5008 mk2 and have poured screen wash in the Adblue tank, not started and ignition hasn't been on.. is there a drain hole on the 5008 ?
Regards
Thanks for this,
Regards
- x 1487
It appears to, front corner opposite side to the filler neck. Make sure to wash it out well with distilled water before refilling.
