How to drain 2015 308 AdBlue tank
grazelgirl
Unread post by grazelgirl »
Hey! I was wondering if someone could help please as I'm needing to drain my 2015 308 adblue tank but can't find anywhere to say how. Any ideas please?
Many thanks Alex xx
x 1055
Re: How to drain 2015 308 AdBlue tank
Unread post by wheeler »
There is a little drain plug on the bottom of the tank (number 5 in the picture)
There is a little torx screw (T-20 from memory) holding the plug in, once you undo this just twit the plug & pull.
Leave the filler cap on initially to make it empty more controlled, Just be ready if you have the filler cap removed it drains out fast.
grazelgirl
Thank you so much!! You're a hero!! Xx
Tibbs1994
New User
Unread post by Tibbs1994 »
Hi
Thanks for this,
I have a 5008 mk2 and have poured screen wash in the Adblue tank, not started and ignition hasn't been on.. is there a drain hole on the 5008 ?
Regards
x 1489
It appears to, front corner opposite side to the filler neck. Make sure to wash it out well with distilled water before refilling.
