Citroen c3 Picasso 1.6hdi FACM location, help please!
lanya
Unread post by lanya »
Hello friends!
I'm new here, but I want to ask for help right away.
Citroen c3 picasso 2010, 1.6hdi, where can I find the FACM?
If you can describe it exactly or attach pictures, I would really appreciate your help!
lanya
Re: Citroen c3 Picasso 1.6hdi FACM location, help please!
can anyone help?
x 6946
We generally refer to these as the Fuel Additive ECU (not the Fuel Additive Control Module that is often referred to on Fords for example).
On most PSA vehicles of this year and later the function is incorporated into the engine ECU. The actual multiplexed additive pump is incorporated into the additive tank.
If you require a parts diagram or you can't already find the info you need on the Forum, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future parts requests for up to 2 years, so excellent value.
If interested, links are below, then pop your VIN up.
A response to your question by a Forum Admin requiring parts or additional information requires you to have made a current contribution (£10 min.) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
lanya
thank you very much for your answer, you helped a lot!
