407 2.7 hdi radiator removal to replace water pipe flange
407
x 22
Unread post by 407 »
Hi
what's the trick to remove the radiator off a 2.7 HDI (so get some free hand / tool space to replace the plastic water flange under the egr )
The cooling fan housing encases the radiator and the air conditioning condensor but I can't see any obvious way to remove the fan housing.
x 6957
Re: 407 2.7 hdi radiator removal to replace water pipe flange
There isn't an easy way - the bumper has to come off along with the upper body supports - basically the front end...
x 22
Thanks Marc
I might try the remove compressor and alternator first and see how I go - seemed easier on the petrol V6 :)
x 6957
If you want I can put a procedure up in the resources section - but please read your PMs first.
x 22
yes please - saves me breaking plastics parts :)
x 6957
jrclarkson
Unread post by jrclarkson »
Am I able to get access to the instructions above? When I click on it I get the "not authorised" message.
x 6957
To access Resources, you need to upgrade your membership - see below:
We can help if you need an original, genuine part number, part diagram, factory build sheet or access to some resources and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
A response to your question by a Forum Admin requiring parts or specific vehicle information requires you
to have made a current contribution
(Min. £10 / €11.48 or equivalent) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
