top brake light c5 mk2 estate
gingernut
Unread post by gingernut »
Hi
Does any one know where I can source (new or used) a rear LED top brake light for a citroen c5 estate mk 2? At the moment im struggling to even find a part number.
Cheers
Gingernut
jamescarruthers
x 47
Re: top brake light c5 mk2 estate
Unread post by jamescarruthers »
They are the same back end as the C5 Mk. 1 and sadly not available from Citroen. You can pass an MOT without it but I don’t like it either!
Part number seems to be 6350 P6. You can get them new on eBay but rather pricey at £95. https://www.ebay.co.uk/itm/154520595605 ... media=COPY
Repair instructions which I’d like to carry out on my sister’s C5 one day… if I ever get round to it: viewtopic.php?t=34108
1987 Volvo 480 ES
2006 Citroen C6 3.0 petrol Exclusive
x 5657
I repaired mine, bulbs readily available on eBay and elsewhere, cheap too.
jamescarruthers
x 47
myglaren wrote: 11 Oct 2022, 14:30 I repaired mine, bulbs readily available on eBay and elsewhere, cheap too.
That gives me some hope, cheers!
1987 Volvo 480 ES
x 6955
jamescarruthers wrote: 11 Oct 2022, 14:07 They are the same back end as the C5 Mk. 1 and sadly not available from Citroen. You can pass an MOT without it but I don’t like it either!
6350 P6 is still showing as available from Citroen parts James, £206.78
jamescarruthers
x 47
GiveMeABreak wrote: 11 Oct 2022, 15:36
Ah, I stand corrected! Get your cheque book out Gingernut! :)
1987 Volvo 480 ES
x 1056
Unread post by wheeler »
Who would really dream of paying over £200 for this? That could easily write a mk1 C5 off.
I repaired my old MK1 C5 one with the strip LED's you just cut to length. Was around £10 for a 5 meter reel.
x 5657
Did you/do you do MOT's?
Just that I read somewhere recently that as long as two of the three brake lights work that it will pass an MOT with an advisory.
I remember repairing mine but not the details, can't remember if it was incandescent bulbs or LEDs. If it was LEDs it was individual ones I put in rather than a strip.
jamescarruthers
x 47
I think there is something weird on the MOT in that you have to have a certain percentage of the middle brake light LEDs working… or it can be completely not working!
1987 Volvo 480 ES
x 1061
Unread post by Rp0thejester »
I've just passed mine with 1 out 2 rear number plate bulbs working. MOTs seem to be getting stranger
x 1061
At what point does a car with an extra brake light count as a fail? Surely it's extra, not needed, how would it affect the safety of the vehicle and others? Can't see that as a fail.
x 6955
It's the usual - it may not be required for the MOT, but where fitted, it must work...
jamescarruthers
x 47
Rp0thejester wrote: 11 Oct 2022, 19:48 I've just passed mine with 1 out 2 rear number plate bulbs working. MOTs seem to be getting stranger
Yeah that is odd isn’t it. My C6 passed like this recently and couldn’t believe it.
1987 Volvo 480 ES
x 8310
If the MoT tester knows you and the car well then if they know and trust you'll fix any problems immediately they'll give a small degree of leeway in my experience...
x 1061
I took it to a while you wait centre where they don't do repairs. I'm assuming the FCF tax disc badge helped and also the new brake line to rear right wheel helped. I think it may be a discretionary decision on the testers part as to whether or not it should be a pass or fail. If got interest in the vehicle and they see work has and is being done then maybe more lenient than a boy racer turning up.... Just my thoughts
