top brake light c5 mk2 estate
gingernut
Hi
Does any one know where I can source (new or used) a rear LED top brake light for a citroen c5 estate mk 2? At the moment im struggling to even find a part number.
Cheers
Gingernut
Cheers
Gingernut
jamescarruthers
- x 47
Re: top brake light c5 mk2 estate
They are the same back end as the C5 Mk. 1 and sadly not available from Citroen. You can pass an MOT without it but I don’t like it either!
Part number seems to be 6350 P6. You can get them new on eBay but rather pricey at £95. https://www.ebay.co.uk/itm/154520595605 ... media=COPY
Repair instructions which I’d like to carry out on my sister’s C5 one day… if I ever get round to it: viewtopic.php?t=34108
1987 Volvo 480 ES
2006 Citroen C6 3.0 petrol Exclusive
- x 5664
I repaired mine, bulbs readily available on eBay and elsewhere, cheap too.
jamescarruthers
- x 47
That gives me some hope, cheers!myglaren wrote: 11 Oct 2022, 14:30 I repaired mine, bulbs readily available on eBay and elsewhere, cheap too.
1987 Volvo 480 ES
- x 6955
6350 P6 is still showing as available from Citroen parts James, £206.78jamescarruthers wrote: 11 Oct 2022, 14:07 They are the same back end as the C5 Mk. 1 and sadly not available from Citroen. You can pass an MOT without it but I don’t like it either!
jamescarruthers
- x 47
Ah, I stand corrected! Get your cheque book out Gingernut!GiveMeABreak wrote: 11 Oct 2022, 15:366350 P6 is still showing as available from Citroen parts James, £206.78jamescarruthers wrote: 11 Oct 2022, 14:07 They are the same back end as the C5 Mk. 1 and sadly not available from Citroen. You can pass an MOT without it but I don’t like it either!
1987 Volvo 480 ES
- x 1056
Who would really dream of paying over £200 for this? That could easily write a mk1 C5 off.
I repaired my old MK1 C5 one with the strip LED's you just cut to length. Was around £10 for a 5 meter reel.
- x 5664
Did you/do you do MOT's?
Just that I read somewhere recently that as long as two of the three brake lights work that it will pass an MOT with an advisory.
I remember repairing mine but not the details, can't remember if it was incandescent bulbs or LEDs. If it was LEDs it was individual ones I put in rather than a strip.
jamescarruthers
- x 47
I think there is something weird on the MOT in that you have to have a certain percentage of the middle brake light LEDs working… or it can be completely not working!
1987 Volvo 480 ES
- x 1064
I've just passed mine with 1 out 2 rear number plate bulbs working. MOTs seem to be getting stranger
Champion of Where's CitroJim
- x 1064
At what point does a car with an extra brake light count as a fail? Surely it's extra, not needed, how would it affect the safety of the vehicle and others? Can't see that as a fail.
- x 6955
It's the usual - it may not be required for the MOT, but where fitted, it must work...
jamescarruthers
- x 47
Yeah that is odd isn’t it. My C6 passed like this recently and couldn’t believe it.Rp0thejester wrote: 11 Oct 2022, 19:48 I've just passed mine with 1 out 2 rear number plate bulbs working. MOTs seem to be getting stranger
1987 Volvo 480 ES
- x 8329
If the MoT tester knows you and the car well then if they know and trust you'll fix any problems immediately they'll give a small degree of leeway in my experience...
- x 1064
I took it to a while you wait centre where they don't do repairs. I'm assuming the FCF tax disc badge helped and also the new brake line to rear right wheel helped. I think it may be a discretionary decision on the testers part as to whether or not it should be a pass or fail. If got interest in the vehicle and they see work has and is being done then maybe more lenient than a boy racer turning up.... Just my thoughts
