Hello all,
Newb's first post here. Bit of background: My wife has a 2011 Peugeot 3008 1.6 Hdi sport. Has been having recurring error with "Risk of Particle filter cogging". Had it brought to a reputable independent who ran diagnostics. Said DPF system was OK - issue was that 3 of 4 injectors were failing - poor combustion then leading to particle filter error. Recommended replacing the 4 injectors.
I've since ordered 4 new injectors. I'm wondering if anyone has a step by step guide, and maybe specific torque settings for this particular engine? Any help would be much appreciated. I won't be doing the work myself, but would like to be able to give it to my local garage, as it won't be going to a main dealer. I've heard the settings can be fairly specific, so I'd like to provide as much info as possible to the garage when handing it over.
Any help much appreciated!!! Thanks in advance for taking the time to read this!
Torque settings - 3008 Injectors
- x 1486
Re: Torque settings - 3008 Injectors
Welcome along!
2011 is on the change over from the 16V to the 8V engine - and the injector clamps and torques are very different - can you confirm which it is? 16V are very sensitive and easily damaged / 8V much more robust!
BenConWex
Hi Richard,
Thanks for the reply.
Any advice on how to tell if it's 8v or 16v?
- x 6957
Just pop your VIN up for us.
BenConWex
Thanks again!
Thanks again!
- x 6957
I’ll get back to you shortly on the other matter, but you have an outstanding after-sales campaign on your vehicle!
This is a DV6C engine and I know that some of these issues affect the injectors and or timing issues, so I would get it in before you do any work on the injectors in case it involves this. The work will be free if charge, but if it has had any intervention by a third party they may decline to do it.
BenConWex
Hi Marc,
What does this mean? Is it like recall work?
- x 6957
DV6C 8 Valve Engine.
Note: DV6C Engine Only!
| Ref | Designation | Stage | Tightening torque |
| (1) | Connections (Diesel injector ) | Pre-tighten | 2 daNm |
| (1) | Connections (Diesel injector ) | Tightening | 2,5 daNm |
| (2) | Connections (Fuel high pressure pipes / Fuel high pressure common injection rail ) | Pre-tighten | 2 daNm |
| (2) | Connections (Fuel high pressure pipes / Fuel high pressure common injection rail ) | Tightening | 2,5 daNm |
| (3) | Union (High-pressure fuel pipe / Fuel high pressure pump) | Pre-tighten | 2 daNm |
| (3) | Union (High-pressure fuel pipe / Fuel high pressure pump) | Tightening | 2,5 daNm |
| (4) | bolts (Fuel high pressure pump rear bracket) | Tightening | 1 daNm |
| (5) | bolts (Fuel high pressure pump rear bracket) | Tightening | 1 daNm |
| (6) | bolts (Diesel injector fixing flange) | Pre-tighten | 0,7 daNm |
| (6) | bolts (Diesel injector fixing flange) | Angular tightening | 80° |
| (7) | bolts (Fuel high pressure pump front bracket) | Tightening | 2 daNm |
| (8) | bolts (Fuel injection pump / Bracket ) | Tightening | 2 daNm |
| (9) | Fuel injection pump pulley nut | Tightening | 5 daNm |
| (10) | bolts (Fuel high pressure pump rear bracket) | Tightening | 2 daNm |
| (11) | bolts (Fuel high pressure common injection rail / Engine block) | Tightening | 2 daNm |
| (12) | Fuel high pressure sensor | Tightening | 4,5 daNm |
| (13) | bolts (Fuel pressure regulator / Fuel high pressure pump) | Pre-tighten | 0,3 daNm |
| (13) | bolts (Fuel pressure regulator / Fuel high pressure pump) | Tightening | 0,7 daNm |
- x 6957
It means there is remedial work that needs carrying out that has been identified and your vehicle (from it's VIN) indicates the work is outstanding. It's not a safety recall, but it is potentially important that you get it done.
I can't tell you specifically what it is for, only the dealer can do that, once you call them and provide the VIN. All I can tell you is that some members have had significant work done FOC as a result. It may be a software update, but equally it could mean new injectors or clamps or timing - or something entirely different.
- x 6957
See my previous post for Torque settings for this engine for the injectors, as I've added the rest of the settings.
BenConWex
Hi Marc,
Main dealer has said it is timing belt and labour, not including water pump. Thank you very much for the heads up!
And thanks for the torque settings!
- x 6957
Well at least that will save you a few quid - but if it was me, I would certainly see if they will do the tensioner pulleys / rollers and the water pump for you if you offered to pay for those parts and the small extra bit of labour.....
- x 1940
^ ^ ^ Exactly what I was going to suggest. And ask about a new auxiliary belt as well as this has to come off to get to the timing belt.
