Looking for a part number for EGR valve
DennyLoi83
(Donor 2021)
Unread post by DennyLoi83 »
I'm confused as to which one I need to purchase as there are so many out there. It's too much of a hassle to get to to take a look at the existing one. Is there any way of identifying the specific one I need? I have a 59 plate C4 Grand Picasso.
Thanks in advance.
x 6946
Re: Looking for a part number for EGR valve
We can help with official parts, but as we are also charged for this data, we ask for a Forum donation. But, this will cover you for any parts enquiries you have for up to 2 years so excellent value.
If you want to go ahead, just follow the links below and pop your VIN up.
A response to your question by a Forum Admin requiring parts or additional information requires you to have made a current contribution (£10 min.) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
DennyLoi83
(Donor 2021)
Sure - i've done the £10 donation.
VIN as follows: VF7**************[VIN obfuscated, can be read by forum staff]
Reason: Spaces removed from VIN
x 1056
Unread post by wheeler »
According to the VIN this is a petrol model?
Does this engine even have an EGR valve?
Does your reg end in AZX?
x 6946
Yes, no EGR on this it's a 1.6 VTi 16V 120 (EP6) engine.
If you're having issues, maybe an explanation of the problems may help and also any fault codes you have from a diagnostic. A diagnostic check should always be the first place to start.
Thanks for your donation, - if there are any part numbers you need let us know - your membership has been upgraded.
DennyLoi83
(Donor 2021)
Thanks guys. Here is a post I made a couple of months ago. It has all the relevant details on it. I just didn't get around to following it up:
viewtopic.php?t=69397
Cheers
DennyLoi83
(Donor 2021)
I just accidentally put the following info on the other post (above), but i'll put it here too:
I should also add the following information:
The ECU under the bonnet, by the battery, burnt out in July and I replaced it with another one from Ebay. After that, these electrical issues (as described in the other post) starting happening. I then replaced the ECU unit with another one from Ebay, but the issues persisted. Both ECU's had the same part numbers as the faulty one. It would seem weird if both ECUs were faulty.
After that, I replaced the radiator fan relay as the radiator fan stopped working. The error existed both before and after I did this.
I've just been ignoring the errors and driving the car as normal as it doesn't seem to make any different to performance. The only noticeable difference is that the handbrake doesn't automatically apply.
x 6946
Ok, I've locked the other thread to avoid duplication in answers and provided a link to this thread.
So the first thing you really need to do is get a proper diagnostic done (preferably with Diagbox) which will be able to read the more advanced systems that generic code readers very likely can't).
Once we have the codes we may be able to help you further. Now we have ascertained this is a petrol engine without an EGR, we can rule that out as having any influence.
DennyLoi83
(Donor 2021)
Thanks guys. Do the faults get stored? When I turn the engine off and back on again, they all clear from the dashboard. I'm just thinking whether I need to force the faults to happen and they go straight to the mechanic, or can I simply get the faulty read even if they don't appear on the dash?
Cheers
x 1056
Yes, the fault should remain in the memory even if the warning light/message is not on at the time.
x 6946
Also there are likely to be faults stored in the BSI / Engine ECU that won't always trigger a dashboard warning. These will also be stored in the log, so even intermittent faults should be able to be recalled by anyone with some experience of using Diagbox or other suitable diagnostic tool.
Doo
(Donor 2022)
x 121
Unread post by Doo »
From experience, most illogical electrical errors can be caused my battery, alternator or earthing issues. On my wife's 2007 Citroen C4, we were experiencing strange issues which turned out to be dirty fuse connections. The actual fuses had got damp (tree's and tree dropping bits storing damp... I don't even know how!!) so I ended up removing the unit, removing every fuse (having taken pictures to be able to replace the fuses in the correct order) and cleaning each fuse holder with a mouse tail flat file (a teeny baby file about 3 or four inches long in total). I replaced everything and off she went without issue. This was about 4yrs ago. It hasn't happened again.
However, if your BCM actual caught fire, did you check the multiplug connection for dirty (green) connections? Are you certain none of the wires melted, shorting out? Although, more likely it could be just a poor connection, resulting in "muddled" signals. Modern cars absolutely "demand" clean signals so any grot on the wiring connection will create issues such as you are suffering.
My 2004 Jaguar XK8 4.2 tells me the ABS and gearbox are at deaths door if the battery has died (common occurrence since it sits for years at a time), but once the battery is fully charged, it's "Hello! I'm back...!"
My advice is check all connections, fuse box, earths, battery terminals and so forth. Good luck.
Has anyone seen the plot? :?
