When placing the car in to "Park" the gear selector snapped off about 2cm from. The bottom. I tried to superglue it but, that lasted 2 minutes. Any ideas on how this can be repaired? Would it be covered under extended warranty? I can still awkwardly change from drive to neutral, reverse etc but it's not ideal.
It's on a c4 picasso bluehdi 1.6 eat6 2016 model.
Any help appreciated.
Snapped automatic gear selector
- x 6955
Re: Snapped automatic gear selector
Hi, it may well be covered under extended warranty as this is not what I would classify as a traditional wear & tear item. If it was structurally defective for it to contribute towards snapping - that's what I would go with as it could be dangerous, so I would push for a warranty replacement as I've not heard of this happening before.
- x 1056
I'd be surprised if they covered this under warranty, Even less likely now you have put superglue on it.
MixerFistit
- x 14
As an easyish fix vs disassembly, I'd think about drilling into both halves and insert a metal rod like part of a nail. Glue will bond much better and the strain will be transferred to the rod. Epoxy would probably be more stable with summer dashboard temperatures but cover everything because you don't want that on the dash.
307 CC 2.0 HDI
Sold/dead
Mk1 Dispatch 06 Face lift - 2.0 HDI - RHZ (sold)
2x xsara picasso 1.6 HDi
2x mk1 C4 Pic and a mk1 C4 GP
1x mk2 C4 Pic
C8 2.2.hdi (6 seat Exc) van/can
207cc 1.6 hdi (project)
Sold/dead
1x mk2 C4 Pic
- x 1480
Post up the VIN and we can check the exact part no, but there only appears to be one - sadly it's £310.... It's just a plug in module, so you should be able to get one from a breaker - e.g. https://www.ebay.co.uk/itm/384437042039 ... SwaFNhBBdN still £150 though....
Dormouse
- x 696
Or....fit an outside tubular collar and pin it twice either side of the break right through the collar.MixerFistit wrote: 22 Oct 2021, 15:48 As an easyish fix vs disassembly, I'd think about drilling into both halves and insert a metal rod like part of a nail. Glue will bond much better and the strain will be transferred to the rod. Epoxy would probably be more stable with summer dashboard temperatures but cover everything because you don't want that on the dash.
Mexico14
VF7**************[VIN obfuscated, can be read by forum staff]RichardW wrote: 22 Oct 2021, 18:31 Post up the VIN and we can check the exact part no, but there only appears to be one - sadly it's £310.... It's just a plug in module, so you should be able to get one from a breaker - e.g. https://www.ebay.co.uk/itm/384437042039 ... SwaFNhBBdN still £150 though....
Is it possible to get a second hand module and replace the arm/stalk? Would a new module need programming at all
- x 1480
That's the right one, part no: 98 002 212 VV
I can't imagine it needs coding, but I can't see any info about it.
Mexico14
Could you show me an example of what you mean please?Dormouse wrote: 22 Oct 2021, 19:32Or....fit an outside tubular collar and pin it twice either side of the break right through the collar.MixerFistit wrote: 22 Oct 2021, 15:48 As an easyish fix vs disassembly, I'd think about drilling into both halves and insert a metal rod like part of a nail. Glue will bond much better and the strain will be transferred to the rod. Epoxy would probably be more stable with summer dashboard temperatures but cover everything because you don't want that on the dash.
admiral51
- (Donor 2026)
- x 391
Mexico14
Thanks Richard. With the Vin number is it possible you could tell me which version of disc and pads I need on my car please ? Its coming up with 2 size options when I enter my reg in to sites.RichardW wrote: 22 Oct 2021, 21:21 That's the right one, part no: 98 002 212 VV
Mexico14
Thanks for your reply, but looking at it, it's so flimsy and not solid plastic throughout bizarrely, I don't think this method would be an option unfortunately.
- x 6955
Here you go:Mexico14 wrote: 25 Oct 2021, 13:02Thanks Richard. With the Vin number is it possible you could tell me which version of disc and pads I need on my car please ? Its coming up with 2 size options when I enter my reg in to sites.RichardW wrote: 22 Oct 2021, 21:21 That's the right one, part no: 98 002 212 VV
Front Discs: OEM Original part 9805961480 for the kit, £78.76
Note that the original disk kit seems at present to be cheaper than the usually cheaper alternative below!
Or PSA recommended Cheaper: 1667851280, £100.43
These are: DIAM 283 EP 26
Front Pads:
OEM 1609898380 £103.19
PSA Recommended Cheaper: 1619791080 £51.78
Prices quoted as of this post and include VAT, direct from your Citroen retailer.
If you need rears, let us know.
