what is this?
saeedm
x 16
what is this?
Unread post by saeedm »
hi there.
i just found this somewhere over the subframe
car is xantia x2 rfv
x 1055
Re: what is this?
Unread post by wheeler »
Looks to me like one of the little mounts used to clip the engine cover on to the top of the engine.
saeedm
x 16
Re: what is this?
but xu10j4r dose not have engine cover
x 2938
Re: what is this?
Looks like an oil filler cap with the top knocked off.
saeedm
x 16
Re: what is this?
it is something like spring loaded valve.
x 2938
Re: what is this?
Difficult to judge the size from the image,
x 3565
Re: what is this?
Part of the gear selector rods ?
x 1746
Re: what is this?
Oil vapour/breather valve ?
x 6946
Re: what is this?
Part of the subframe?
x 2938
Re: what is this?
white exec wrote: 20 Sep 2021, 19:58 Oil vapour/breather valve ?
That was my thought too, in looks like the filler cap with built in valve to keep the crankcase in negative pressure.
x 1941
Re: what is this?
Unread post by Paul-R »
Could you post another photo with a ruler or something to give us a sense of the size? It's difficult get an idea of the scale involved.
x 1055
Re: what is this?
bobins wrote: 20 Sep 2021, 19:43 Part of the gear selector rods ?
That’s exactly what it is, its the inside part of a gear selector rod end. Didn’t realise it was spring loaded from the picture.
x 3565
Re: what is this?
Do I win a prize ? :-D :lol:
saeedm
x 16
Re: what is this?
this is the size of it on hand
and valve is not loose and need some force to push it. like 1 - 2kg force
x 1746
Re: what is this?
So, a spring-loaded (anti-rattle) insert, for a gear-change coupling?
Gosh.
