C5 front suspension strut interchangeability
vfrrsvr
- (Donor 2021)
Hi Gents and any ladies that may have be here. I am in need of some advice, possibly no more than opinion. My son has a 2004 C5 HDI. I have just put in a new clutch and renewed the handbrake cables (OMG!). I noticed that the front strut mounting on both sides was a bit of a mess. Very rusty, not surface but had turned into layers of rust flakes, I am sure you know the scene. The rusty bit is the outer part of the mount that is integral to the strut. It carries the three studs that locate in the inner wing. Inner wing is sound. It appears I have a couple of options here. One option which will not happen is to get new bits from Citroen. Too dear if available. Option 2 is to buy the strut top from ebay, usually from abroad. They are in good nick but how good is the seal btn the strut and the removed top mount?. Option three is the most likely and it is here I need guidance. Buy two complete second hand struts. There are a couple currently on ebay. BUT they are from a 2005 model. My hope is that the facelift was just that and that the mechanicals with the exception of the later engine and ancillaries remained unchanged. Answers on a postcard please will 2005 struts fit a 2004 C5. The only difference that I know of is that these removable tops come with two different thread sizes for the hydaulic lines either circa m8 and the other circa m14. On of the Polish vendors has photos of his vernier measuring each. I originally suspected that 2001-4 were m8 and 2004-8 were the larger size, but these ebay 2005 ones seem to be the smaller size. Any comment on this much appreciated.
- x 3296
Re: C5 front suspension strut interchangeability
Hi, and
to the forum. I believe the main difference is between C5s with standard suspension (otherwise known as H3) and those with Sports suspension (known as H3+). I have a copy of DocBackup, and just doing a quick comparison between same spec Mk1 and Facelift C5s suggests that the strut tops are the same, as the parts numbers are the same (but, as I have said, you must make sure they suspension is of the same spec). The quick way to check would be to look at the suspension control buttons. H3 has the 'Up' and 'Down' buttons (with the name 'Citroen' between them), while H3+ has the 'Sport' button replacing the 'Citroen' name, like these two ebay links;
https://www.ebay.co.uk/itm/284418252698 ... SwiFVhIKmG
https://www.ebay.co.uk/itm/223754370127 ... SwCoRdEckC
I hope that this helps you.
- x 6945
The MK I and MK II strut brackets are still available and about £300 each.VFR**************[VIN obfuscated, can be read by forum staff] wrote: 22 Aug 2021, 21:41One option which will not happen is to get new bits from Citroen. Too dear if available.
As for the front struts from a MK I - they are the same as the MK II with the same part numbers.
vfrrsvr
- (Donor 2021)
Ha Ha More questions. First, thank you guys for your prompt assistance. Marc do you have part numbers for the strut tops, wouldnt hurt to ask Citroen, they might have a special offer on !. Also opinion Mk1 or Mk2 C5 I see you have had both. I want another hydro car before they disappear. I like the 8 valve hdi. I have a 16v hdi 1.6 in my wifes Xsara Picasso and its a pain having glow plugs etc down the back of the engine,. I assume its the same with the Hdi 2.0 16v. Puts me off the mk2. Is it worth the perceived bother?
Thanks for the welcome but I have been here before. 31MEV not banned just lost my details and no matter what I did, could not get back in. Not a frequent visitor, contribute little, but come here to assist in keeping 4 old Citroens on the road so hope I will be excused a rather one sided arrangement.
- x 5672
Shame you didn't ask - we can restore your account for you if you want!
- x 6945
Ok so personally, I would plump for the MK II. Less 'squeaky', more solid feel, better engines, the 2.0 HDI is a workhorse and solid engine. Don't worry about glowplugs, rarely needed on an HDI - only assists regeneration occasionally or in very cold starting conditions. I've never changed a glow plug on an HDi- ever.VFR**************[VIN obfuscated, can be read by forum staff] wrote: 23 Aug 2021, 20:05 Ha Ha More questions. First, thank you guys for your prompt assistance. Marc do you have part numbers for the strut tops, wouldnt hurt to ask Citroen, they might have a special offer on !. Also opinion Mk1 or Mk2 C5 I see you have had both. I want another hydro car before they disappear. I like the 8 valve hdi. I have a 16v hdi 1.6 in my wifes Xsara Picasso and its a pain having glow plugs etc down the back of the engine,. I assume its the same with the Hdi 2.0 16v. Puts me off the mk2. Is it worth the perceived bother?
The MK II has nice styling - the rear especially on a saloon is very unique and unmistakable. Better options - directional b-Xenon headlamps are a great feature with the full electric leather seats if you can get a nice exclusive and improved hydractive suspension over the MK I.
Parts are drying up, so if you are not opting for a MK III (X7) get in quick.
As for parts info generally, we can provide official live part numbers and parts diagrams, but as we are no charged by PSA for this data, we do ask for a donation. The good news is that upgrading your membership will provide you with part number requests for up to 2 years. Just follow the links below - it's all automated and then pop up your VIN for the vehicle in question to save me asking for it in future.
| A response to your question by a Forum Admin requiring Parts or additional information requires you to have made a current contribution (£10 min.) to the Forum. |
| To Upgrade Your Membership & Donate Click Here For Further Information About Parts Information and VIN Numbers Click Here |
vfrrsvr
- (Donor 2021)
Hi Again the following is a follow on from the posts above there has been some delay but as advised by Givemeabreak we have sourced new strut tops. I now need to change them. Clearly the bottom of the strut needs disconnecting. I have seen this done on you tube. I think I am ok there. My questions all therefore relate to the top end. When I disconnect the hydraulic line is there a rubber seal that sits un the end of the pipe like the old CX's? I would like to think that if I remove the large nut on the top of the strut, the strut will pull out of the mounting. I suspect it is more involved as many of the second hand tops that I looked at on ebay had the plastic flare/guard around the mid point damaged. There is a hole behind the flare that would give access to the body of the strut (not the shaft) is there some sort of one way clip there.? Any help would be appreciated. Also I have made a donation but could not get back to the entry point. I believe it said to contact Jim. Was that just for stickers?
- x 6945
Have a read through Elis's guide on doing this - lots of photos and videos and other information:
viewtopic.php?t=58759
vfrrsvr
- (Donor 2021)
Hi Marc
I have read through, but it refers to X7 struts in the main. There is a passing reference to a Mk1/2 but the guy takes it to a garage. To simplify my question, If I remove the large nut on top of the strut will it separate the mounting from the strut, or is there some other hidden fixing. Thanks for your suggestion
- x 6945
Why did I think you had an X7?
I'll see if I can find something for you....
Here you go, this is the official procedure:
C5 MK I & II Front Strut Replacement
vfrrsvr
- (Donor 2021)
Spot on Marc. Thank you very much. My Son really fancied an X7 until I told him of all the probs I had read about on here with racks. I am a CX man at heart. Stuck inside a Xsara Picasso (my wifes). When it comes to Citroens, in my view, older is better. with many caveats!!
- x 6945
No problems.
The X7 is a great car in my opinion and far superior to the previous models, despite being on my third rack before selling her - but some people are luckier than others. The 'CV Boot Mod' can be used as detailed here by many of us to help prevent water getting onto the pinion shaft that causes the rusting and O-ring seal deformation / destruction. To my knowledge, everyone here who has undertaken the mod has been trouble-free with the racks since.
Just be wary of parts now as the MK I & II are getting quite old and availability of some parts is getting an issue - especially suspension parts like struts.
vfrrsvr
- (Donor 2021)
Thanks for that Marc. One last Q if I may. I know the 2.2 engine had its problems in the mk1. Did that carry over to the mk2? add to that the 178hp version. Your thoughts would be appreciated. I only ask as I have seen a nice one for sale and always thought I would avoid, in favour of the 2.0 am I missing something here?
- x 6945
The MK II or MK I Facelifted) had the following 2.2 engines:
(4HX) DW12TED4 (136 HP) Euro 3, 4 Speed Auto
(4HT) DW12BTED4 (173 HP) Euro 4, Manual
