C5 x7 v6 TTD Engine overheating
hayden641946
- (Donor 2021)
- x 5
Is there a valve in the cooling system that can be faulty and shut off the coolant to flow all the way through the engine ????
- x 6948
Re: C5 x7 v6 TTD Engine overheating
What are the faults / symptoms? There was a modification to the cooling outlet housing on Euro 5 vehicles, relating to incidents with the engine coolant temperature sensor.
See my illustrated post here:
viewtopic.php?p=640455#p640455
- x 1476
That post is for the EP engines, I think not relavent here.GiveMeABreak wrote: 11 May 2021, 08:43 What are the faults / symptoms? There was a modification to the cooling outlet housing on Euro 5 vehicles, relating to incidents with the engine coolant temperature sensor.
- x 6948
I just rechecked and it does refer to the EP engines you are correct -so ignore that one.
hayden641946
- (Donor 2021)
- x 5
My wife phoned me from 5 klms away and said a warning sign had come up on the instrument , STOP ENGINE OVERHEATING .
I said drive home slowly and I will look for problem .
I had to add 5 litres of coolant to the tank after engine cooled , which seems a lot as it holds about 10 litres full .
I couldn't see a leak and today after a shopping trip I checked again and the plastic tank was empty . I thought the worse that a head gasket may have gone and the coolant was blowing out the exhaust !!
Decided to do an engine oil change as it was due at 170000 klm . Upon removing the large plastic tray under the engine I noticed cooling fluid on tray and now ran onto the garage floor .
Has anyone had a leak from their C5 X7 V6 3.0 L around the rear ?? of the engine as I have not found the source yet ??
- x 6948
Have a look at the diagram below Hayden. Let me know which suspected area 'A' to 'E' the leak is coming from, bearing in mind gravity - so the source of the leak. You may need to take a few pics, dry the area up, then watch for the leak again to get the source.
Click Image to Zoom
Click Image to Zoom
hayden641946
- (Donor 2021)
- x 5
Thanks for the drawings Marc ,
I have found the leak and it is in a very hard to access position . I will try and attach photos and the rough sketch I did .
It appears to be leaking from a black plastic housing position under the front injection manifold and directly behind the yellow handle of dip stick .
The cooling fluid was dripping from the lower mounting screw head , there are two hoses connected , the smaller one leads forward to an aluminium pipe . I think this housing may be located into the cast iron block with a spigot !!!?? this may be where it is leaking . The housing is above the air con compressor ! I don't know what to remove to get at this black housing . It would be unlikely that the screw needs tightening , which would be extremely hard without removing something . Hope you have some ideas please !!
hayden641946
- (Donor 2021)
- x 5
- x 6948
Here? - This is the EGR exchanger coolant inlet and outlet pipes...
or on the Timing Face here:
... or none of the above
hayden641946
- (Donor 2021)
- x 5
Thanks Marc,
Is it shown in the timing side view as brown hoses at top of drawing ? There are two hoses connected and how do I get it out please ?
- x 6948
Ok, so if it is on the timing face, the likely culprit can be the water pump tot he Cylinder block.
Information
Sealing
Possible Causes
Repair
Information
Sealing
- Detachable seal
- 3 bolts
Possible Causes
- Incorrect tightening of the fixing bolts
- Gasket sealing fault
- No seal
- Cracks
Repair
- Replace the seal (If there is a leak localised at the seal)
- Replace the water pump (If there are cracks)
hayden641946
- (Donor 2021)
- x 5
Thanks for this info and help Marc but I think it is really tucked in behind the EGR exchanger . It is black plastic sort of oval shape and I can only see one mounting screw looking up from the ground as shown in the photo . It must have a name which would show in a proper manual !
Can you recommend a workshop manual for this vehicle as there are various companies selling paper and online manuals .
Hayden
Hayden
- x 6948
The problem is trying to localise it and then I can provide some likely leak suspects areas around those places.
I can put up some parts diagrams of the various areas, but we ask for a min. £10 Forum donation for this as we are charged by PSA. But it will cover you for parts info requests for up to 2 years if interested. Details below:
If this would be of use, follow the links in the table and then pop your VIN up here (automasked on post submission), then I can get some parts diagrams up on the cooling and EGR exchanger.
| A response to your question by a Forum Admin will require detailed vehicle information that requires you to have made a current contribution to the Forum. |
| Donate Further Information |
- x 1476
It sounds like the leak is from the front EGR cooler.
MGmike
- x 63
Not sure if the same applies to the 3.0 but I guess it will...
On a 2.7 in the area below the EGR and above the alternator (where you have drawn) is the water inlet manifold.
A common fault on the 2.7 at around 8-10 years old along with the thermostat housing on the top of the engine.
If you haven't renewed either I would recommend doing both at the same time.
I am however assuming the X7 is the same as the C6!
