C5 mk11 Suspension Cylinder Leak
micky707
Unread post by micky707 »
Hi guys, I need a replacement suspension cylinder unit for a 2006 C5 for the rear drivers side, uk, are the left and right identical units? my citroen mechanic has not been able to source a second hand one, any ideas. tia, mick
Micky
Citroen C5 2.0 HDI VTR 138 48k
Citroen Xsara 1.6SX Brilliant car, 9 years and 119000 Miles
2 Pug 306's
Peugeot 207 1.4 Sport
Citroen ZX 1.9D
If it aint broke.......
micky707
Re: C5 mk11 Suspension Cylinder Leak
Would it be a better idea to rebuild original as this one is leaking?
Micky
2 Pug 306's
Citroen ZX 1.9D
x 6955
There are different versions depending on whether you have Hydractive 3 plus with auto adjustment or non-Hydractive and the left and right ones are different for each too.
If you want part numbers, please see below, but only the rear left, non-hydractive strut is currently available new from Citroen.
A response to your question by a Forum Admin will require detailed vehicle information that requires you to have made a current contribution to the Forum.
Donate
Further Information
micky707
Thanks for the reply Marc, I did see a left side available, wasnt sure if they were the same though, Cheers
Micky
2 Pug 306's
Citroen ZX 1.9D
MGmike
x 63
Unread post by MGmike »
Micky,
Getting cylinders is becoming difficult and I guess a breaker is your best bet. I know someone breaking one local to me, let me know if you'd like me to enquire.
However, a DIY overhaul is not that difficult (i've done both of mine). You should be able to get seals from eurocarcare.net but there are different sizes for the reasons Marc mentions above (H3+ etc). There's also a very good chance the pipe will have rusted and break when attempting removal.
best of luck
MGmike
micky707
Ok, thanks Mike, I had a new rubber boot fitted recently so pipe should be fine, Im thinking I'll probably get shot this year so maybe just live with it till then, It is Hydractive
Cheers, Micky
Micky
2 Pug 306's
Citroen ZX 1.9D
MGmike
x 63
Micky,
The boot can be replaced without taking the cylinder off the car and therefore no need to remove the pipe.
