C5 mk11 Suspension Cylinder Leak
Hi guys, I need a replacement suspension cylinder unit for a 2006 C5 for the rear drivers side, uk, are the left and right identical units? my citroen mechanic has not been able to source a second hand one, any ideas. tia, mick
Micky
Citroen C5 2.0 HDI VTR 138 48k
Citroen Xsara 1.6SX Brilliant car, 9 years and 119000 Miles
2 Pug 306's
Peugeot 207 1.4 Sport
Citroen ZX 1.9D
If it aint broke.......
2 Pug 306's
Citroen ZX 1.9D
Re: C5 mk11 Suspension Cylinder Leak
Would it be a better idea to rebuild original as this one is leaking?
Micky
2 Pug 306's
Citroen ZX 1.9D
2 Pug 306's
Citroen ZX 1.9D
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5739
There are different versions depending on whether you have Hydractive 3 plus with auto adjustment or non-Hydractive and the left and right ones are different for each too.
If you want part numbers, please see below, but only the rear left, non-hydractive strut is currently available new from Citroen.
A response to your question by a Forum Admin will require detailed vehicle information that requires you to have made a current contribution to the Forum. |
Donate Further Information |
Thanks for the reply Marc, I did see a left side available, wasnt sure if they were the same though, Cheers
Micky
2 Pug 306's
Citroen ZX 1.9D
2 Pug 306's
Citroen ZX 1.9D
- My Cars: 59 C6 2.7 Red
56 C6 2.7 Blue
55 C5 II Blue
Plus many MG's from 58 to 97
Oh and a Jag XK8! - x 39
Micky,
Getting cylinders is becoming difficult and I guess a breaker is your best bet. I know someone breaking one local to me, let me know if you'd like me to enquire.
However, a DIY overhaul is not that difficult (i've done both of mine). You should be able to get seals from eurocarcare.net but there are different sizes for the reasons Marc mentions above (H3+ etc). There's also a very good chance the pipe will have rusted and break when attempting removal.
best of luck
MGmike
best of luck
MGmike
Ok, thanks Mike, I had a new rubber boot fitted recently so pipe should be fine, Im thinking I'll probably get shot this year so maybe just live with it till then, It is Hydractive
Cheers, Micky
Cheers, Micky
Micky
2 Pug 306's
Citroen ZX 1.9D
2 Pug 306's
Citroen ZX 1.9D
56 C6 2.7 Blue
55 C5 II Blue
Micky,
The boot can be replaced without taking the cylinder off the car and therefore no need to remove the pipe.
