Front and rear brake discs and pads please.
With regard to the OEM rear discs is there an option for item complete with bearings and magnetic rings- or is this just an aftermarket thing?
Tony
Part no. request
discv
- x 24
Part no. request
C4 Grand Picasso 1.6 HDi 16V FAP/DPFS 110, -Auto (DV6 - 80kW) (C4) (DT) (2006-2008)
Toyota Aygo Black 2007 [well almost a french car!]
Xsara Picasso 2.0 Hdi Exclusive 2005
1220 GS Service Van RHD 1973
- x 6957
Re: Part no. request
Leave it with me Tony, I’ll sort this out shortly.
discv
- x 24
As always- thanks Marc. No worries.
- x 6957
Front Discs:
Citroen OEM, Part 4249J6 £156.04 (for both discs)
Citroen cheaper option: 1618862780 £75.76 (for both discs)
Front pads:
Citroen OEM, Part 1647862480 £100.25
Citroen cheaper option: 1617272980 £42.96
Rear Discs:
Citroen OEM, Part 424946 £128.17 (each)
Citroen cheaper option: 1619238880 £94.86 (each)
Rear Pads:
Citroen OEM, Part 1611141080 £70.14
Citroen cheaper option: 1617271880 £33.36
The rear ABS ring is available part: 454919 £16.00 each.
All prices VAT inclusive as of today from Citroen.
Front pads:
Rear Discs:
Rear Pads:
- x 1487
By default the rears come with bearings as there is no separate hub. I imagine the OE ones, and any branded after market ones will come with the ABS sender on, I would expect only cheap ones will come without. You can remove the ring and swap it over, but there must be a risk of breaking it, I'd get decent ones with the ring on!! Note you need a 36mm socket for the rear hub nut, the 35mm one you might have in your tool box to fit the front hub nuts is too small
discv
- x 24
Thanks- great stuff. It's interesting to note that, for example, OEM front discs and pads come to 256.
Citroen fixed price say they will do the job for 245 all in- and they claim Original Parts.
- x 1487
I imagine that will be using the cheaper parts, which comes to £120 + the labour.
- x 3306
That will be down to bulk buying. If you or I buy parts for a car it will be for one car, so we would pay for that (as, among other things, we will be buying the packaging for one set). When large dealerships buy common parts (such as for brakes) they could be ordering a hundred sets of brakes, so less paperwork and the packaging will be for a large number of sets, so less packaging per set; hence the savings.discv wrote: 20 Feb 2021, 14:53 Thanks- great stuff. It's interesting to note that, for example, OEM front discs and pads come to 256.
Steve Walsh
- x 516
Prices quoted are also retail, the dealer buys in at trade and has a decent mark up
discv
- x 24
They appear to claim original parts- who knows?!RichardW wrote: 20 Feb 2021, 15:35 I imagine that will be using the cheaper parts, which comes to £120 + the labour.
- x 6957
Yes, what this equates to is as you have found - the 'Essentials' uses the cheaper Citroen recommended parts and the 'Originals' uses the OEM parts.
But as Richard says, the prices provided are retail to the customer or garage that doesn't have any discount (trade or loyalty) applied. Franchised dealers will get these at a much reduced price.
discv
- x 24
I'm tearing my hair out on this simple job!
I opted for Bremo front discs and pads- not the cheapest aftermarket option, but good specs.
The sizes and type of bolts for the front cylinder and the front caliper retaining bolts are giving me a problem. The required tools are not in my box.
The caliper bolts, I think, are H7 hex?
The retaining bolts are some type of torx?
I'd appreciate a pointer here- as I've got to shell out for the needed socket bits!
Tony
Tony
- x 6957
The brake Caliper Fixing Screws (7) on the diagram are: 12 X 150-36.
