Lucas Pump Stop Solenoid coded ?
PaulVmax
Unread post by PaulVmax »
Hello,
Is the Lucas Stop Solenoid coded to the immobiliser on a 2005 1.9D Pug Expert.
Long story short, my fuel pump died. So I fitted a new fuel pump timing belt and water pump. Easy enough job.
Wouldn't start pulled the injector pipes off at the pump cranked it and no fuel.
The pump I fitted was second hand but the gent assured me the pump was good.
The solenoid is getting 12v and the earth is a good ground.
So its ether a Faulty solenoid, I have already removed a known good one out of the old pump i bench tested this work fine, or the solenoid needs to be coded.
Thank you.
x 1052
Re: Lucas Pump Stop Solenoid coded ?
Unread post by wheeler »
On a 2005 it will be a coded stop solenoid. I doubt you will be able to recode a used one to your van.
Is this a DW8 engine or XUD?
PaulVmax
DW8 engine I think. I will fit the old one that i know works to the pump then thank you.
x 1240
Unread post by Peter.N. »
I believe the coded one has a multiple wire connector, the uncoded one just a screw terminal - its a long time since I've seen one but that's how I remember them.
