C4 Grand Picasso 2007 hdi 1.6 auto non crank
Wildrat
Unread post by Wildrat »
Hi hope someone can help have issue with starting on wife’s car
Have had issues recently with getting to select gears before starting and only working in manual mode.
Believe this is from bad battery?
But has now failed to start have fitted new Bosh Battery and starter but still no start checked fuses and dash is all good just no start, non crank at all. no click.
Does anyone have any pointers or the starting circuit diagram?
Am engineer but bit difficult without road map?
Thanks John :?
x 1053
Re: C4 Grand Picasso 2007 hdi 1.6 auto non crank
Unread post by wheeler »
Is it a proper auto or EGS?
Is the gear selector on the dash showing its in N or P?
Have you tried direct feeding the starter to see if it cranks?
Wildrat
EGS
Gear showing correctly
Starter new and tested
x 1053
Does the engine start when you direct feed the starter?
To get a wiring diagram I need the RP number from the tyre pressure label.
Wildrat
I will do so tonight thanks m8
Wildrat
Sorry bit to wet down here but is this the info ?
x 3296
11244FV. If the decoder is right your car stated production on 22nd August 2007 in the Vigo factory, Spain
x 1053
1010 = starter motor
PSF1 = under bonnet fusebox
1320 = injection ECU
Wildrat
Thanks a lot will try to trace issue now
Wildrat
Noticed I have power on both sides of fuse 8 starter ? looking at diag! its through an relay would that be part of the BSI ? solid state ? if so would that be the issue
x 1053
The starter relay is integral to the under bonnet fusebox (PSF1).
Cranking needs to be authorised first though. Does the engine start if you direct feed the starter with the ignition on?
