Hi All,
Looking for the procedure to remove and refit control solenoid valves at back of the engine, I'm sure I've seen it on another thread.
I found a version but it has 4 valves whereas mine has 3
Can anyone help
Kenny
Control solenoids Valves
KennyW
- x 165
C3 1.4 petrol (SWMBO)
lexi
- x 133
Re: Control solenoids Valves
Kenny: Are you trying to overtake Marc with total component replacement on an X7?
Marc only has the cup holders to do for a full house!
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
OnlinePaul-R
- x 1938
He has two?
- x 6945
3 actually!
Don't forget the 2 in the back seat armrest.....
@Kenny - I'll sort something for you tomorrow.
- x 5672
The two in the front of mine are hopeless, Hardly anything fits and is very easy to knock over. I use the ashtray, it is never used for anything else (the ashtray between the front seats)
SO I have 5! Nahnahnahnah
OnlinePaul-R
- x 1938
I've never sat in the back of my X7 so I had to go out and have look. I didn't see any cup holders so thought the Estate might be different to the saloon but then I saw a little pull out tray in the armrest. Who knew?
- x 6945
I'm putting a guide together now Kenny, so won't be long.KennyW wrote: 01 May 2020, 22:12 Hi All,
Can anyone help
Kenny
- x 6945
Removing the Control Solenoid Valves (Turbocharger, Inlet Air Mixing, Inlet Air Cooling & EGR) on a DW10CTED4 C5 X7
Location Of Valves
Disconnect the battery following BSI Reset / Battery Disconnect / Reconnect Procedure
Remove Heat Shield
Turbocharger pressure regulation solenoid valve
EGR cooling solenoid valve
Inlet air cooling solenoid valve
Inlet air mixer control electrovalve
In all cases, follow the reconnection part of the BSI Reset / Battery Disconnect / Reconnect Procedure
Location Of Valves
| (1) The turbocharger pressure regulation electrovalve. (2) EGR cooling solenoid valve. (3) Inlet air cooling solenoid valve. (4) Inlet air mixer control electrovalve. |
Remove:
| Remove as shown |
| Remove the bolts (7). Uncouple and move aside the vacuum circuit pipes ( as "b"). Note: Mark the position of each vacuum pipe! Disconnect the connector (at "c"). Remove the turbocharger pressure regulation solenoid valve (1). Refitting Refit the turbocharger pressure regulation solenoid valve (1). Couple the vacuum circuit pipes ( as "b"). Note: When refitting, do not reverse the vacuum pipes . Connect the connector ( as "c"). Refit the bolts (7). |
| Remove the bolts (8). Uncouple and move aside the vacuum circuit pipes ( as "e"). Note: Mark the position of each vacuum pipe! Disconnect the connector (at "d"). Remove the EGR cooling solenoid valve (2). Refitting Refit the EGR cooling solenoid valve (2). Couple the vacuum circuit pipes ( as "e"). Note: When refitting, do not reverse the vacuum pipes . Connect the connector ( as "d"). Refit the bolts (8). |
| Remove the bolts (9). Uncouple and move aside the vacuum circuit pipes ( as "g"). Note: Mark the position of each vacuum pipe! Disconnect the connector (at "f"). Remove the inlet air cooling solenoid valve (3). Refitting Refit the inlet air cooling solenoid valve (3). Couple the vacuum circuit pipes ( as "g"). Note: When refitting, do not reverse the vacuum pipes . Connect the connector ( as "f"). Refit the bolts (9). |
| Remove the bolts (10). Uncouple and move aside the vacuum circuit pipes ( as "j"). Note: Mark the position of each vacuum pipe! Disconnect the connector (at "h"). Remove the inlet air mixer control electrovalve (4). Refitting Refit the inlet air mixer control electrovalve (4). Couple the vacuum circuit pipes ( as "j"). Note: When refitting, do not reverse the vacuum pipes . Connect the connector ( as "h"). Refit the bolts (10). |
KennyW
- x 165
Thanks Marc,
Okay I have only 3 valves not 4 as above so they have not bothered to update their files.
The vacuum pipe 7 in service citroen changed at 12291 with one less port.
The removal fitting procedure is the same but with 1 less control valve. I do not know why.
FYI Marc that is the same procedure I have.
Kenny
Kenny
- x 6945
I recall I posted posted about it somewhere a while ago now, but can't remember - it was a few years ago now.
