Filter DS5
Filter DS5
Air filter and pollen filter, know where they are located and what their reference number is so that I can replace them my VIN number is VF7**************[VIN obfuscated, can be read by forum staff], thanks
- Donor 2020
Re: Filter DS5
When I changed the filter on my THP155 petrol I removed the wipers and scuttle panels from under windscreen to improve access to the air filter. I don't know if diesels have the same problem. There are YouTube videos around that show access to the cabin filter (2 of) and it varies according to whether the vehicle is LHD or RHD. Either way some panels and ducting need to be removed. Not a simple job.
- x 2343
Re: Filter DS5
I'm not sure if you have the info that you need now, but if not and still need parts info, please see the note below first:
A response to your question by a forum admin will require detailed vehicle information that requires you to have made a current contribution to the Forum. |
Donate Further Information |
Re: Filter DS5
Well, the truth is that I haven't thought of it before but I think the diesel HYBRIDs are different and he filter is more or less in the center attached to the radiator
