Peugeot 407 EGT Sensor
Miggi
Unread post by Miggi »
I have a 2007 407 2.0 HDI coupe, fault code p2033 displayed. Can you confirm part No for my EGT sensor is 1618PG/ SH/ 30. And are there any less expensive variants I can use.
Many thanks.
x 6957
Re: Peugeot 407 EGT Sensor
To ensure correct parts, you'll need to post up your VIN (automatically masked from public view). We also use this to ensure the fault description is accurate for your particular engine ECU as the variables differ.
Miggi
Hi Marc my vin is, VF3**************[VIN obfuscated, can be read by forum staff]. Can you also advise me on any Torque requirements for the replacement part.
Again thanks.
x 6957
Confirmed, the newer replacement part is 1618PG (item 2 below). Currently priced at £146.30 inc. VAT from Peugeot.
Torque: 3.0 ± 0.5 daNm
Be wary of non OEM replacements - I suspect the replacement part may have a slightly longer cable, due to the earlier model getting too close to the heat from the exhaust and causing damage to the wiring sheath, leading to electrical shorts / damage. The newer replacement part may have a longer cable, in order that it can be secured further away from the exhaust.
Miggi
Thanks Marc now all I need to do is squeezing under the dam thing
And do the do.
