Hi all, this is my first post so please excuse Me if i break any etiquette rules.
I have just acquired a 2011 citroen c3 1.4 hdi vtr. When i start the engine the car pings a warning up, engine temperature fault- stop engine. I then drive for a bit and it goes off. When i come to a junction and have to inch forward or idle, it pings up the same warning. It goes off a short time after setting of with normal driving speeds. I have changed the obvious thermostat housing and coolant temp sensor today and it has made no difference. There are no codes coming up on scanner. Can anyone tell me if it has another sensor somewhere on the head or any other advice as to what to check.
C3 engine temp fault - stop engine help
- x 6947
Re: C3 engine temp fault - stop engine help
You'll find that some generic scanners are unable to read the ECUs of the more modern engines, and especially the constructor-specific codes.
A warning like that will have triggered a fault code - even if temporary, and that will be stored in the BSI. You'll really need somebody with Diagbox to pull it off. If you can get that we may be able to help explain what she's not happy about.
Please pop your VIN up here (automatically masked from public view) and I'll be able to locate the sensor for you with a diagram.
- x 1472
At a guess, I would suggest that it is likely to be a corroded connector or a break in a wire going to the engine ECU. If the fault is reliably present at a cold start, then it should not be too difficult to track down, even by measuring some voltages in the absence of diagnostic equipment to read the live data.
C3wilson
Wow thanks for the swift response. The vin is VF7**************[VIN obfuscated, can be read by forum staff]
- x 6947
Ok, so the water temperature sensor is item (2) on the diagram.
Part number 1338C1 (DIAM 25,4-LONG 53) in case you need it.
C3wilson
Thanks for that diagram, the sensor no 2 i have already changed. I have not had time to investigate further but it has been suggested today that it may be the water pump, that is causing the fault as the light/fault only illuminates when engine is idle 10 seconds after acceleration it goes off and stays off while normal driving. They suggested that the coolant may not be being circulated fast enough due to impeller failure. Any thoughts on this?
- x 6947
I’d have to say it’s a possibility but not a common fault. My dealer actually asked me if I was sure I wanted the water pump doing when having the timing belt changed as he said they were very reliable and very rarely failed these days.
That’s not to say they won’t of course. If your timing belt is due maybe you could get that done at the same time as it will save on labour costs if not doing it yourself.
If you could determine if there is a stored specific fault code that would help troubleshoot.
JohnL73
- New User
Was there a final solution for this issue ?
My C3 has now thrown the same fault any help would be very mu h appreciated.
Karasek+4
@johnL73 Have you solved the problem? Currently I have te same one. Do not know what to do. I have xhanged so many parts related to the car temperature but the same mistake is beeping.
Karasek+4
The problem was the sensor on the coolant bottle
