C5 x7 electric seats in car with non-electric seats ?
shone
Unread post by shone »
Hello to everyone,
I just buy seats from exclusive c5 2008-2011, with electric motors inside the seats, heats, massage option on one and so on...., full leather.
My idea is to try to put this seats in my C5 2009 non-exclusive, with standard seats.
If anyone know the electric scheme for connector or can give me any advice it would be wonderful. I notice that those main connector below the seats are the same like in my car, but amount of wires are not the same, I have 8 (two doubles) while there is 15 (two doubles) in seat with no massage, while in those with massage there is 16 wires on main connector.
I guess it is not a good idea to just plug new seats on my car ? Maybe it will work, without memory for the position of the seat, of course, but I afraid to try that because I am not sure that the wires position and power are on the right place between each connectors, no matter if it look the same.
If someone have experience in this, please ?
Thanks in advance.
x 6945
Re: C5 x7 electric seats in car with non-electric seats ?
Nope - it simply won't work as a swap.
I don't know if you have an Exclusive X7 or not - but the wiring harnesses are different for a start. Next the Door Control Module will also be different and not compatible.
Another member had an Exclusive with non-leather seats - so he had most of the wiring, but had to get the door cards and the control module fitted and some other things. These are not like the earlier MK I C5s where most of the wiring was in place. The X7 has multiple wiring looms, Front, Supplementary, Fascia, Intermediate and rear for the cabin and these are all different depending on model and build date.
shone
Thank you for your reply.
So there is no chance via original connector, from my non-exclusive car.
This means that only way will be if I can connect power to the seats an make it work as stand alone units.
Is there someone who, at least, try this seats work with connected power outside of the car ?
x 6945
That won’t really work as the system relies on connected electronic control units in the seats that talk to the control modules and the BSI. These are multiplexed electronics on a CAN network
If you have your VIN I can see what module you have and what harnesses. Do you also have the year of the donor vehicle from which the seats are from?
x 1240
Unread post by Peter.N. »
I fitted leather electric seats in my Mk1 C5 and all the connectors were under the carpet but I think the electronics have changed a bit since then.
x 5672
Dead easy on the Mk 1.
x 6945
Apart from the modifications to some of the earlier engines, there is nothing else whatsoever the X7 has in common with the earlier C5 MK I or MK II. It's a completely different vehicle. :wink:
shone
GiveMeABreak wrote: 26 Oct 2019, 10:26 That won’t really work as the system relies on connected electronic control units in the seats that talk to the control modules and the BSI. These are multiplexed electronics on a CAN network
Thank you a lot for your effort.
My VIN is VF7**************[VIN obfuscated, can be read by forum staff], while donor seats are from c5 2010., if I can I will try to get also vin from donor car. Seats are full, both with heats while driver seat have massage.
x 6945
I compared my X7 that is about the same build date and engine as yours (but right hand drive) as I have all the kit on mine from factory - so could check the harness details (comparing with the Left Hand Drive equivalent harness with same functions)
So you don't have the Driver's control unit, for the Electric Seats and ambient lighting, shown as item (20) on the Diagram.
You also have a different Seat and Belt Harness for vehicles without Electric Heated Seats and Memory Control:
And also the Front Door Harness is different for vehicles without Ambient Lighting and Electrochromed, Memory Controlled, Heated, Folding Indexed Mirrors
You obviously have a Left Hand Drive, so the harnesses are different - but I have looked at these too for you and they are still different for non-controlled, memory heated seats.
I think I mentioned that another member changed the door cards and had to have the control module sent as the wiring int he door was different as I mentioned above.
shone
It looks this is mission imposible for me. Only way at the moment I see in solution to make seats working as stand a lone, only sensor for belt and airbag can be connected with slightly changes. :(
x 6945
Just be careful what you do - if you accidentally trigger the airbag it could be really dangerous.
shone
Yes, I know about airbag, actually I am searching for some instruction how to open seats, especially those backplate plastic, how to unmount it from sets so that I can take a closer look to everything inside.
I am curious what will hapened if I connect it to my car, since connector is the same, at least phisicaly ? Hmm.
aronbv
x 4
Unread post by aronbv »
shone wrote: 26 Oct 2019, 18:19 Yes, I know about airbag, actually I am searching for some instruction how to open seats, especially those backplate plastic, how to unmount it from sets so that I can take a closer look to everything inside.
So, here i am, practically with the same problem, I have the seats, but without massage and heating. How could i power them? Any advice is greatly appreciated.
x 6945
You have to remember that all these control components are integrated into the comfort CAN data network. All the control units talk to each other and then to the BSI. You need the right harnesses and control units. The main ECU under the seat has tie ins to the various motors ion the seats and other electronics and these need to connect to the right electrical harness to talk to the other systems and components in the door and BSI, fusebox etc. These aren't like the MK I or MK II seats that were simpler to retrofit, because of the additional functions and features and further integration.
Steveo
x 13
Unread post by Steveo »
Hi all
Any update on this retro fit?
Regards
Steve
