suspension ecu
KennyW
x 165
suspension ecu
Unread post by KennyW »
After much nashing of teeth etc got a laptop running with xp pro to run diagbox. BUT it appears there is no communication between diagbox and suspension control unit during globel test it appears in RED Communication Error. All previous global tests have been the same but I just thought it was me with electronics :rofl2:
I suspect a broken wire running from diagnostic socket to Sus control unit.
Any other suggestions ?
Multi meter at the ready.
Kenny
C3 1.4 petrol (SWMBO)
x 6957
Re: suspension ecu
Kenny - what is the name of the ECU that is in red that is not communicating - do you have a screenshot of the global test section that shows this please?
I ask as there are 2 units - one built into the BHI (suspension ECOTECH) and the other (Suspension CSS) that is separate. The CSS one you do not have as this is only for 6 cylinder engines, so you will never be able to access it. If not this then please advise.
KennyW
x 165
Re: suspension ecu
I'll get a screen shot for you.
KennyW
x 165
Re: suspension ecu
Marc,
Please find attached photo
global test screen shot
x 6957
Re: suspension ecu
That's probably it then. You don't have directional headlamps either and that also shows a comms issue - to be expected.
Can you confirm on the next screens if you are seeing Suspension 'ECOTECH'. That should be visible.
KennyW
x 165
Re: suspension ecu
Marc,
I'm sure there is no suspension ecotec further down the test.
I presume the global test no matter where it is started will check ALL available ECU's.
Kenny
x 6957
Re: suspension ecu
Yes, for a unique session. Always start a new global test at the beginning. You should have suspension eco tech listed for sure.
Any changes made to the software since you last used it?
Try with engine running and make sure the cable isn’t strained, pulling on the pins.
KennyW
x 165
Re: suspension ecu
Marc,
I'm going to check again for the Suspension ECU
x 6957
Re: suspension ecu
This is the suspension ECU you should have Kenny, arrowed in yellow:
KennyW
x 165
Re: suspension ecu
Marc,
Definitely no other suspension ecu on global test.
Thus I have a electrical problem hopefully a broken wire. But where ?
The Sus ECU has always displayed this error when I have done a global test.I wonder if this is the reason it was sold.
Kenny
x 6957
Re: suspension ecu
Just confirm your Diagbox version please Kenny
KennyW
x 165
Re: suspension ecu
7.57
x 6957
Re: suspension ecu
No issues that I can see concerning later versions in relation to error corrections - although with 7.58 you do get the option to test by ECU that is missing in 7.57.
KennyW
x 165
Re: suspension ecu
Worth upgrading or get the multimeter out.
Kenny
x 1460
Re: suspension ecu
Unread post by xantia_v6 »
Am I correct in thinking (I don't have diagbox or suitable car handy) that the BSI configuration pages contain a list of the ECUs that the car is configured to have?
