Hello, does anyone have the part number for the front height corrector linkage. The part with the split collar that clamps to the anti-roll bar? Number 3 in the second picture here:
https://www.ebay.co.uk/itm/Genuine-Fron ... SwQVZZfvXh
Or has a spare one?
Mine is repairable, but a new or good used one would obviously be better. Thank you in advance.
Front Height Corrector Part Needed.
- x 6954
Re: Front Height Corrector Part Needed.
Part No: 529103, priced £4.31 from Citroen inc. VAT - still showing as available.
- x 16
Thanks a lot. Cheap too.
Edit: it's the part in the accompanying diagram, part # 3, not the part that the seller is selling.
I think it is: 529113 ?
1080
- x 16
Lots available in Russia and Argentina, but nothing in UK or Europe.
- x 6954
The part I quoted was Item (6) below - if not this, let me know what item yo do need.
- x 6954
Items 3 and 4 are no longer available and the part numbers are different - so if you still need the number, pop your VIN up.
- x 16
Yes, I've found out part 3 is no longer available. That is the part I need.
I'll repair this one. Part number is definitely 529113 for item 3 same for all Xantias with non-hydractive. Thanks.
- x 6954
They're actually not - there are 2 possibilities for a non ARCS system...
529113 (Diameter 22)
529114 (Diameter 23) - Estates and (XU10J4 engines to 31/05/1995)
- x 16
If anyone has a 22mm used one they don't need, or even a 23 mm (I'll machine a sleeve) then I would be happy to buy. Thank for your in-depth replies, moderator.
I would also be grateful if anyone knows of a breaker with a Xantia in the Lancashire area. It's been 20 years since I closed my garage business and a similar time since I last went to the breakers. I've messaged a few sellers on eBay who have Xantias for spares, but no luck so far. I have started making a new part, but other jobs have got in the was up to now.
