'09 Exclusive driveshaft fitting.
milleplod
x 15
Unread post by milleplod »
Afternoon all.
I've already bought the complete nearside driveshaft as the CV joints aren't available seperately for the autos apparently. When fitting it - more specifically, when removing the old one! - am I likely to lose loads of transmission fluid?! :shock: If I do lose some and manage to save it in a clean container, am I OK to simply put that back in via the filler? :?
Pete
Nocto Diuque Venamur.
x 2938
Re: '09 Exclusive driveshaft fitting.
I don't know which box is in your car but the AM6 box is built in such a way that the drive shafts can be removed without any fluid loss.
milleplod
x 15
Gibbo2286 wrote: 15 Jun 2018, 14:48 I don't know which box is in your car but the AM6 box is built in such a way that the drive shafts can be removed without any fluid loss.
Its the AM6, so that's good news - thanks! :)
Pete
x 6950
Here's what I have Pete in case it helps:
Official Tools
[6310-T] Hub immobilising tool
[5707-T] Swivel ball-pin extractor
Removing
  • Depressurise the hydraulic suspension circuit with the aid of a diagnostic tool (according to equipment).
  • Lift and support the vehicle with the wheels free.
  • Remove the front wheels.
  • Remove the under engine protection .
  • Drain the gearbox (Manual gearbox only).
  • Fit the tool [6310-T]
Remove:
  • The pin (4)
  • The steel cage (3)
  • The drive shaft nut (2)
  • The tool [6310-T]
  • The bracket (1)
Remove:
  • The anti-roll bar link rod (5)
  • The nut (8)
  • The mountings (7)
  • Uncouple the steering ball joint (6); Using tool [5707-T] or ball joint separator.
L.H. driveshaft
  • Release the LH driveshaft by pivoting the front half-axle upwards.
  • Remove the L.H. driveshaft.
Right hand drive shaft
  • Undo the 2 screws (9) of the RH driveshaft bearing.
  • Move aside the circlip (10) in the direction of the arrow "a".
  • Release the RH driveshaft by pivoting the front half-axle upwards.
  • Remove the right-hand drive shaft.
Refitting
Replace the drive shaft seals using the tools [7114-T.X], [7114-T.W], [0332-A], [0332-B], [0346-R], [0346-S].
  • Refit :
  • The drive shafts
  • The bolts (9)
  • The mountings (7)
  • The steering ball joint (6)
  • The nut (8)
  • The nut (11)
  • The nut (12)
  • The bracket (1)
milleplod
x 15
Thanks for the info Marc, should come in handy! I'll report back as to how it went.
Pete
milleplod
x 15
All done! It only took us ('us' in the loosest sense of the word, I just made coffee and handed my mate the tools, as required! :lol: ) about 1hr 15mins, no glitches, no leaks, nice and simple.....and now its nice and quiet too! :-D
As a bonus, he fitted me some LEDs in place of the DRL bulbs while I was there, as one went a couple of weeks ago - the nearside one came out easily, the offside one was an absolute pig to get out, it took almost as long as it did to swap the driveshaft! :shock:
Pete
x 6950
That'll be the DRLs all right, a swine of a job!
