Good afternoon,
Can anyone explain how to get the tailgate to open. There is no reaction/sound/click when I push the Button (?) to open it.
Joe
Pluriel 2004 - Tailgate will not open
- x 1487
Re: Pluriel 2004 - Tailgate will not open
It would be worth trying a BSI reset procedure.
This video might also be instructive:
JosephM
Thanks. Will try.
JosephM
I manage to open the tailgate following the video instruction. Now I need to go to an electrician to fing out what is wrong with the electrics. Thanks.
furriegurrie
- x 40
If the roof has lost it's position and as a result does not know if it is fully opened or closed the tailgate won't open either. This happens when wear on the cogg or the cables that move the roof causes slippage. Reinitilisation of the roof might cure your problem. But if the cables slip you can usually not finish that procedure successfully
- x 1487
JosephM wrote: 12 Jun 2018, 10:03 I manage to open the tailgate following the video instruction. Now I need to go to an electrician to fing out what is wrong with the electrics. Thanks.
Glad that you have made some progress.
You need to check that whoever tries to diagnose it has a Lexia/Diagbox tool, as it would be hopeless without. If you can't find anyone in Malta with one, maybe you should invest in one yourself.
