Pluriel 2004 - Tailgate will not open
JosephM
Unread post by JosephM »
Good afternoon,
Can anyone explain how to get the tailgate to open. There is no reaction/sound/click when I push the Button (?) to open it.
Joe
x 1460
Re: Pluriel 2004 - Tailgate will not open
Unread post by xantia_v6 »
It would be worth trying a BSI reset procedure.
This video might also be instructive:
JosephM
Thanks. Will try.
JosephM
I manage to open the tailgate following the video instruction. Now I need to go to an electrician to fing out what is wrong with the electrics. Thanks.
furriegurrie
x 40
Unread post by furriegurrie »
If the roof has lost it's position and as a result does not know if it is fully opened or closed the tailgate won't open either. This happens when wear on the cogg or the cables that move the roof causes slippage. Reinitilisation of the roof might cure your problem. But if the cables slip you can usually not finish that procedure successfully
x 1460
JosephM wrote: 12 Jun 2018, 10:03 I manage to open the tailgate following the video instruction. Now I need to go to an electrician to fing out what is wrong with the electrics. Thanks.
Glad that you have made some progress.
You need to check that whoever tries to diagnose it has a Lexia/Diagbox tool, as it would be hopeless without. If you can't find anyone in Malta with one, maybe you should invest in one yourself.
