AX Rear brake adjustment guide ?
- x 1996
Who can point me to a good guide online.
All a bit "off" atm after new H-B cables/shoes fitted and butchered non-standard springs found etc.
- x 8418
Re: AX Rear brake adjustment guide ?
They should be auto-adjusters on an AX Alasdair so if all is working properly they should sort themselves out after a push or three on the footbrake and several applications of the handbrake...
Thing is, getting the auto adjusters to work can be a game... I have been there many times
Have you a picture? I ask as there may have been several variants fitted...
If they look like the Saxo ones then I'll scan up the relevant BoL pages for you...
- x 5672
Long, long ago there was a procedure for getting the rear drums to auto-adjust by reversing fairly rapidly and heaving the handbrake on.
I have no idea if this was universal but it did work for me on many occasions.
- x 1996
All done now, I was being a total nob with the self-adjuster cam on the shoes
- x 8418
Stickyfinger wrote: 01 Feb 2018, 17:12 All done now, I was being a total nob with the self-adjuster cam on the shoes
No, don't be so hard on yourself Alasdair - it's not obvious and the BoL is terrible in its guidance... Had you read it you'd have been none the wiser...
Today's reading is from the Book of Saxo, Chapter 9, Verse 8 - which has identical rear brakes to the AX:
That's as clear as Somerset scrumpy thenAnd the Lord of the Drum did speak, saying thou may find that it may be necessary to shorten the adjuster strut length, by rotating the strut wheel...
- x 1996
I do not even have a BoLies to go by
- x 8418
You don't need one, trust me
- x 1996
true, but not as many laughs per page
van ordinaire
- (Donor 2017)
- x 400
BoL is only a source of laughter when read through our collective jaundiced eye - pity the por novice who, not unreasonably, believes it can all be taken as gospel.
Citroens:-
'81 2CV Club
'05 C15
'97 Xantia Exclusive estate
others:-
Jeep XJ Cherokees x 3
'96 Cadillac Eldorado
'99 Cadillac STS
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
- x 8418
Yes, on balance the BoL is funnier... Mind you, some threads on this very forum put up a good fight for the title
That is the worrying part.... I think they may be in cahoots with the motor trade to drum up work for them...van ordinaire wrote: 01 Feb 2018, 23:18 BoL is only a source of laughter when read through our collective jaundiced eye - pity the por novice who, not unreasonably, believes it can all be taken as gospel.
van ordinaire
- (Donor 2017)
- x 400
Suggest you contact Ray Davies & ask if he can revise Vilage Green Preservation Society to include a name check for your new organisation.
Citroens:-
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
- x 8418
Pug_XUD_KeenAmateur
- (Donor 2018)
- x 228
that was me, thirty years ago... you know you're old when! !van ordinaire wrote: 01 Feb 2018, 23:18 ....pity the por novice who believes [the BoL] can all be taken as gospel.
Puxa
van ordinaire
- (Donor 2017)
- x 400
I only learned they are actually wrong in places when I got a 2CV, prior to that the only fault I found was an over-fondness for removing things that weren't necessary for the job in hand.
However, just to put it into perspective, this from the GM manual on removing a Cadillac hazard switch, accompanied by a diagram, "1 2 3" &, just like Haynes, reassembly is the reverse - but expessed thus: "3 2 1"
Citroens:-
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
- x 1996
