AX Rear brake adjustment guide ?
x 2009
Unread post by Stickyfinger »
Who can point me to a good guide online.
All a bit "off" atm after new H-B cables/shoes fitted and butchered non-standard springs found etc.
x 8469
Re: AX Rear brake adjustment guide ?
They should be auto-adjusters on an AX Alasdair so if all is working properly they should sort themselves out after a push or three on the footbrake and several applications of the handbrake...
Thing is, getting the auto adjusters to work can be a game... I have been there many times :twisted:
Have you a picture? I ask as there may have been several variants fitted...
If they look like the Saxo ones then I'll scan up the relevant BoL pages for you...
x 5690
Long, long ago there was a procedure for getting the rear drums to auto-adjust by reversing fairly rapidly and heaving the handbrake on.
I have no idea if this was universal but it did work for me on many occasions.
x 2009
All done now, I was being a total nob with the self-adjuster cam on the shoes
x 8469
Stickyfinger wrote: 01 Feb 2018, 17:12 All done now, I was being a total nob with the self-adjuster cam on the shoes
No, don't be so hard on yourself Alasdair - it's not obvious and the BoL is terrible in its guidance... Had you read it you'd have been none the wiser...
Today's reading is from the Book of Saxo, Chapter 9, Verse 8 - which has identical rear brakes to the AX:
And the Lord of the Drum did speak, saying thou may find that it may be necessary to shorten the adjuster strut length, by rotating the strut wheel...
That's as clear as Somerset scrumpy then :twisted: :lol:
x 2009
I do not even have a BoLies to go by :)
x 8469
Stickyfinger wrote: 01 Feb 2018, 17:42 I do not even have a BoLies to go by :)
You don't need one, trust me ;) This forum is far better than any BoL...
x 2009
true, but not as many laughs per page :)
van ordinaire
(Donor 2017)
x 400
BoL is only a source of laughter when read through our collective jaundiced eye - pity the por novice who, not unreasonably, believes it can all be taken as gospel.
Citroens:-
'81 2CV Club :cry:
'05 C15 :!:
others:-
Jeep XJ Cherokees x 3 :?
'96 Cadillac Eldorado
'99 Cadillac STS :|
x 8469
Stickyfinger wrote: 01 Feb 2018, 18:07 true, but not as many laughs per page :)
Yes, on balance the BoL is funnier... Mind you, some threads on this very forum put up a good fight for the title ;)
van ordinaire wrote: 01 Feb 2018, 23:18 BoL is only a source of laughter when read through our collective jaundiced eye - pity the por novice who, not unreasonably, believes it can all be taken as gospel.
That is the worrying part.... I think they may be in cahoots with the motor trade to drum up work for them...
van ordinaire
(Donor 2017)
x 400
Suggest you contact Ray Davies & ask if he can revise Vilage Green Preservation Society to include a name check for your new organisation.
Citroens:-
'81 2CV Club :cry:
'05 C15 :!:
others:-
'99 Cadillac STS :|
x 8469
Van, a great idea!!!
Pug_XUD_KeenAmateur
(Donor 2018)
x 228
van ordinaire wrote: 01 Feb 2018, 23:18 ....pity the por novice who believes [the BoL] can all be taken as gospel.
that was me, thirty years ago... you know you're old when! !
Puxa
van ordinaire
(Donor 2017)
x 400
I only learned they are actually wrong in places when I got a 2CV, prior to that the only fault I found was an over-fondness for removing things that weren't necessary for the job in hand.
However, just to put it into perspective, this from the GM manual on removing a Cadillac hazard switch, accompanied by a diagram, "1 2 3" &, just like Haynes, reassembly is the reverse - but expessed thus: "3 2 1"
Citroens:-
'81 2CV Club :cry:
'05 C15 :!:
others:-
'99 Cadillac STS :|
x 2009
Written by Ted Rodgers ?
