Checking Level of LDS
C5_Jack
Hello All
Is there a way to check the level of the LDS?
I may have a small leak from the off side rear strut, so I want to check if I am loosing fluid.
Cheers
Jack
Cheers
Jack
- x 3280
Re: Checking Level of LDS
Drop the C5 down to its' lowest setting, and then take off the LDS cap. There is a 'basket' type of mesh in there, with some vertical slots lower than others. The LDS should be between these levels (lower are minimum, higher are maximum). This image may explain it;
https://www.bing.com/images/search?q=ci ... ajaxhist=0
C5_Jack
Hi James
The picture is to show the vertical slots only?
If yes the fluid is not even touching the base of the "basket".
Jack
Jack
- x 3280
In this picture there is no fluid. You can see the height difference between the slots. When the car is bottomed out (but not de-pressurised) you should see fluid between the lower and upper levels.
- x 6953
The fluid levels should be checked with suspension depressurised (ideally), but as James says, put it on the lowest suspension level and wait for it to fully lower. The following diagram shows the levels for a C5 X7 - the BLUE being the maximum fill level and the ORANGE the minimum level.
C5_Jack
Hi
I need to add close to 1.5 ltr of fluid to be between the high and low level!
I will keep an eye on it for leaks
Jack
Jack
deksa
GiveMeABreak wrote: 18 Oct 2016, 12:25 The fluid levels should be checked with suspension depressurised (ideally), but as James says, put it on the lowest suspension level and wait for it to fully lower. The following diagram shows the levels for a C5 X7 - the BLUE being the maximum fill level and he ORANGE the minimum level.
What about C5 mk1? Is it the same diagram?
- x 6953
Yes, same, do not fill above the blue mark and check on lowest suspension setting.
Jonesy2064
Does it matter whether you do this with the engine running or not? Did mine yesterday with the engine off and there appears to be fluid marks around the half way seam on the tank. I only filled it till it covered the bottom of the cage and I could actually see it (1/2 litre.) Hopefully this is just the residue of the bit that got spilt in the wind
Regards
J
Regards
J
- x 6953
Level must be between A and B as per my last post, checked on lowest setting, engine can be running.
Jonesy2064
Thanks for the quick response Marc. Well I did it with the engine off and suspension on low. Will check again after a few days running around and hopefully will not find further worrying signs.
Best Regards
J
Best Regards
J
- x 6953
Are you suspecting a leak somewhere then?
If not too windy, stick some cardboard down on the ground, under the engine bay towards the centre rear of the engine. Check back in the morning to see if there has been any significant drips.
mmatin
So, can lds be fill while engine running? Also what is the right procedure, remove tank cap and the rise and lower the car, or first lower then remove cap?
Mario Matin
- x 6953
I answered that 3 posts ago^
GiveMeABreak wrote: 09 Dec 2018, 18:41 Level must be between A and B as per my last post, checked on lowest setting, engine can be running.
mmatin
