radio feed
froggy
- (Donor 2026)
- x 4
radio feed
Hi, just replaced the battery connections on my S1 Xantia. The radio now does"nt work ! I have no power ! fuse is ok , any ideas anyone, cheers Terry.
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
- x 1450
Re: radio feed
There are 2 supplies and fuses for the radio (via ignition switch and direct). Is the display completely blank?
froggy
- (Donor 2026)
- x 4
Re: radio feed
yes
Terry
froggy
- (Donor 2026)
- x 4
Re: radio feed
Are both fuses under steering wheel ?
Terry
van ordinaire
- (Donor 2017)
- x 402
Re: radio feed
Where are we going with "Is the display completely blank?"? - I ask because I have a completely blank screen on an otherwise fully operational stereo.
Citroens:-
'81 2CV Club
'05 C15
'97 Xantia Exclusive estate
others:-
Jeep XJ Cherokees x 3
'96 Cadillac Eldorado
'99 Cadillac STS
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
froggy
- (Donor 2026)
- x 4
Re: radio feed
resolved ! thanks
Terry
- x 1999
harryp
- x 73
Re: radio feed
...yes, Don't be shy
. Please share with the rest of us; that's what we're here for
Regards, Harry
2000 Nov Forte HDI 110 hatch in Wicked Red; currently SORN
2000 Mar Exclusive HDI hatch in Quartz; currently SORN
2013 C4 Picasso Excl E
Peugeot 207cc 1.6 Roland Garros
- x 8353
Re: radio feed
Yes, I want to know too as my Activa wireless randomly looses power, just as it's been switched off...
It may have the same root cause...
froggy
- (Donor 2026)
- x 4
Re: radio feed
Haha... me shy
I removed all fuses from under dash.....used a small air line ( very carefully). cleaned everything and replaced all fuses. The car was full of 20 year old "grot" though. touch wood the radio is now ok
just basically remove everything and thorough clean. Terry.
Terry
- x 8353
Re: radio feed
Excellent
Thanks Terry!
Fusebox issues are starting to become quite common now. I must go do same to mine...
- x 1450
Re: radio feed
Be aware that the fuse panels can also suffer from unreliable internal soldered joints (generally repairable)
Old-Guy
- x 24
Re: radio feed
Really? Like wiper intermittent relays? There's a (nasty) surprise.xantia_v6 wrote:Be aware that the fuse panels can also suffer from unreliable internal soldered joints (generally repairable)
Seriously, I'm always horrified at the crappy quality of automotive electrics. A dozen years ago I was appalled to find that the internal circuitry in my Montego's rear light units was stamped out of electroplated sheet steel - which went rusty when a bit of moisture got in. Not repairable, new light unit - excessive cost cutting in the last years of sorry story of BL/Rover. Saw the same problem a couple of weeks ago on an Audi A6 7 or 8 years old - German quality
