radio feed
froggy
(Donor 2026)
x 4
radio feed
Unread post by froggy »
Hi, just replaced the battery connections on my S1 Xantia. The radio now does"nt work ! I have no power ! fuse is ok , any ideas anyone, cheers Terry.
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
x 1461
Re: radio feed
Unread post by xantia_v6 »
There are 2 supplies and fuses for the radio (via ignition switch and direct). Is the display completely blank?
froggy
(Donor 2026)
x 4
Re: radio feed
yes
Terry
froggy
(Donor 2026)
x 4
Re: radio feed
Are both fuses under steering wheel ?
Terry
van ordinaire
(Donor 2017)
x 402
Re: radio feed
Where are we going with "Is the display completely blank?"? - I ask because I have a completely blank screen on an otherwise fully operational stereo.
Citroens:-
'81 2CV Club :cry:
'05 C15 :!:
others:-
Jeep XJ Cherokees x 3 :?
'96 Cadillac Eldorado
'99 Cadillac STS :|
froggy
(Donor 2026)
x 4
Re: radio feed
resolved ! thanks
Terry
x 2005
Re: radio feed
Unread post by Stickyfinger »
eeeer...good for you :)
....how ?
harryp
(Donor 2022)
x 73
Re: radio feed
Unread post by harryp »
...yes, Don't be shy :wink: . Please share with the rest of us; that's what we're here for :) .
Regards, Harry
2000 Nov Forte HDI 110 hatch in Wicked Red; currently SORN
2000 Mar Exclusive HDI hatch in Quartz; currently SORN
2013 C4 Picasso Excl E
Peugeot 207cc 1.6 Roland Garros
x 8391
Re: radio feed
Yes, I want to know too as my Activa wireless randomly looses power, just as it's been switched off...
It may have the same root cause...
froggy
(Donor 2026)
x 4
Re: radio feed
Haha... me shy :) I removed all fuses from under dash.....used a small air line ( very carefully). cleaned everything and replaced all fuses. The car was full of 20 year old "grot" though. touch wood the radio is now ok [-o< just basically remove everything and thorough clean. Terry.
Terry
x 8391
Re: radio feed
Excellent =D> Thanks Terry!
Fusebox issues are starting to become quite common now. I must go do same to mine...
x 1461
Re: radio feed
Be aware that the fuse panels can also suffer from unreliable internal soldered joints (generally repairable)
Old-Guy
x 24
Re: radio feed
Unread post by Old-Guy »
xantia_v6 wrote:Be aware that the fuse panels can also suffer from unreliable internal soldered joints (generally repairable)
Really? Like wiper intermittent relays? There's a (nasty) surprise.
Seriously, I'm always horrified at the crappy quality of automotive electrics. A dozen years ago I was appalled to find that the internal circuitry in my Montego's rear light units was stamped out of electroplated sheet steel - which went rusty when a bit of moisture got in. Not repairable, new light unit - excessive cost cutting in the last years of sorry story of BL/Rover. Saw the same problem a couple of weeks ago on an Audi A6 7 or 8 years old - German quality :rofl2: eye-watering price for a new cluster.
