Xantia brake valve
Chetiya Dias
Xantia brake valve
Hi everyone. My brake valve back O ring has failed and slightly leaking. Can I have some advice on replacing the O ring.
2000 Xantia 2. 2.0i 16v
VertVega
- x 13
Re: Xantia brake valve
Until you get some instructions on replacing the seal here is a tip which hopefully would help a bit.
Search in FCF with these words: "Doseur valve"
Chetiya Dias
Thanks a lot.VertVega wrote:Until you get some instructions on replacing the seal here is a tip which hopefully would help a bit.
- x 94
if it is leaking into the cab by the pedals you will require
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT Selection
5424455 CNTRL-UNIT RING 3.88 GBP 4.66 GBP 4.66 GBP
95640067 BRAKE PROTECTOR 7.18 GBP 8.62 GBP 8.62 GBP
these price's are copied from a post i made some time ago, so there might be a slight difference now
Regards, malcolm.
- x 2008
I have a question for you, I need a part for a Honda scooter imported to India and Sri Lanka ect.....can you order parts there ?..the part is small and does not weigh much.
Chetiya Dias
The leaking seal is not the one attached in picture. Its the O ring that is leaking.citronut wrote:if it is leaking into the cab by the pedals you will require
Jaf
- x 42
The seal in your photograph is the seal citronut has said. I know because I just replaced mine and that's what it looks like.
The doseur comes out fairly easily. 4 x 8mm metal LHM pipes, 2 x rubber LHM pipes. 2 x 45 torx screws hold the doseur in. On my car there is another LHM unit clamped onto the bottom of the doseur, held on by a small screw at the top.
Fred, a silver 1998 1.9TD SX Xantia.
Gwin, a white 1994 1.1 AX.
Chetiya Dias
The seal in the previously attached picture is fine. But the other side O ring is one thats leaking.Jaf wrote:The seal in your photograph is the seal citronut has said. I know because I just replaced mine and that's what it looks like.
VertVega
- x 13
So it is part number 9 in above diagram which is leaking.
--- 09 _____ 95 638 813 _____ BRAKE O-RING _____ TOR 42 T1,6
- x 2008
I asked this, is it possible ?Stickyfinger wrote:I have a question for you, I need a part for a Honda scooter imported to India and Sri Lanka ect.....can you order parts there ?..the part is small and does not weigh much.
Chetiya Dias
What's the part your looking for. I will try whether its available here.Stickyfinger wrote:I asked this, is it possible ?Stickyfinger wrote:I have a question for you, I need a part for a Honda scooter imported to India and Sri Lanka ect.....can you order parts there ?..the part is small and does not weigh much.
- x 2008
PM sentChetiya Dias wrote:What's the part your looking for. I will try whether its available here.Stickyfinger wrote:I asked this, is it possible ?Stickyfinger wrote:I have a question for you, I need a part for a Honda scooter imported to India and Sri Lanka ect.....can you order parts there ?..the part is small and does not weigh much.
