Xantia brake valve
Chetiya Dias
Xantia brake valve
Unread post by Chetiya Dias »
Hi everyone. My brake valve back O ring has failed and slightly leaking. Can I have some advice on replacing the O ring.
2000 Xantia 2. 2.0i 16v
VertVega
x 13
Re: Xantia brake valve
Unread post by VertVega »
Until you get some instructions on replacing the seal here is a tip which hopefully would help a bit.
Search in FCF with these words: "Doseur valve"
Chetiya Dias
VertVega wrote:Until you get some instructions on replacing the seal here is a tip which hopefully would help a bit.
Thanks a lot.
x 94
Unread post by citronut »
if it is leaking into the cab by the pedals you will require
5424455 CNTRL-UNIT RING 3.88 GBP 4.66 GBP 4.66 GBP
95640067 BRAKE PROTECTOR 7.18 GBP 8.62 GBP 8.62 GBP
these price's are copied from a post i made some time ago, so there might be a slight difference now
Regards, malcolm.
x 2008
Unread post by Stickyfinger »
I have a question for you, I need a part for a Honda scooter imported to India and Sri Lanka ect.....can you order parts there ?..the part is small and does not weigh much.
Chetiya Dias
citronut wrote:if it is leaking into the cab by the pedals you will require
The leaking seal is not the one attached in picture. Its the O ring that is leaking.Image
Jaf
x 42
Unread post by Jaf »
The seal in your photograph is the seal citronut has said. I know because I just replaced mine and that's what it looks like.
The doseur comes out fairly easily. 4 x 8mm metal LHM pipes, 2 x rubber LHM pipes. 2 x 45 torx screws hold the doseur in. On my car there is another LHM unit clamped onto the bottom of the doseur, held on by a small screw at the top.
Fred, a silver 1998 1.9TD SX Xantia.
Gwin, a white 1994 1.1 AX.
Chetiya Dias
Jaf wrote:The seal in your photograph is the seal citronut has said. I know because I just replaced mine and that's what it looks like.
The seal in the previously attached picture is fine. But the other side O ring is one thats leaking.
VertVega
x 13
So it is part number 9 in above diagram which is leaking.
--- 09 _____ 95 638 813 _____ BRAKE O-RING _____ TOR 42 T1,6
x 2008
Stickyfinger wrote:I have a question for you, I need a part for a Honda scooter imported to India and Sri Lanka ect.....can you order parts there ?..the part is small and does not weigh much.
I asked this, is it possible ?
Chetiya Dias
What's the part your looking for. I will try whether its available here.
x 2008
PM sent
