Thank YOU Citroen for my pressie this morning
- x 1996
A car that will not raise at the rear !....feck !
Not looked yet....but anything special to look for on the X7 C5 Tourer Exclusive....I am presuming grease the dog bone/ free the height adjuster ?
DickieG
- Monaco's youngest playboy
- x 33
Re: Thank YOU Citroen for my pressie this morning
Have you tried using the manual height adjustment buttons?
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
vborovic
- Locked user account
- x 40
I can't find the topic, but I recall someone having a similar problem, turned out it was one of the rear height connectors (or the wires from it) ... things like this make me happy that I'm on a regular suspension ...
... but I do share your concern as a fellow X7 owner
DHallworth
- x 167
That's a right bugger on Christmas Day! The one day you hope the car will work without fault when you go to visit family!
'98 Xantia Activa V6
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
- x 1996
Going to take Mother to Church....teach me for not being a believer !
Rear boot buttons not working due to "fault" I expect
Front end goes full up and down all OK
Did a re-set....no change
Jumped on it....no change
Lexia not on new LapTop.....now it will not install !
|Feck this season to be Jolly
citroenxm
- Fallen Hero
- x 70
I doubt VERY much we will ever get dog bone issues with ANY C5 models, Mk.1, 2 or X7 ...
The rear height sensor is a Slack moving potentiometer, and will never suffer from sticky issues like the Xantias STUPID.. and I emphasise the STUPID too as it is the only model to have the complex stupid setup!
So, height - will be as above either a wire, or a dud height sensor at the back.
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 1996
Question, how to get under the bugger with its fat arse on the ground ?
citroenxm
- Fallen Hero
- x 70
Yea a good one that, short of backing up some home made ramps with planks and bricks to lift the rear up, not sure what else at the moment....
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 1996
jacks, bricks, jacks, bricks, jacks, bricks, jacks, Axel stands
Richard_C
- (Donor 2026)
- x 228
A day late I know and hope you have it sorted by now.
You can sometimes get enought clearance to slither underneath a car by driving one side up onto as high a kerb as you can find, ideally not over a drain grid ....
Have you tried a total battery disconnect...cup of coffee....reconnect? Seem unlikely but might be worth a go.
Richard_C
- x 1996
WRONGdoubt VERY much we will ever get dog bone issues with ANY C5 models, Mk.1, 2 or X7 ...
Broken Dog-Bone Shaft....the ball on Potentiometer was seized as was the roll bar one, the pressure had shaped the metal dog-bone shaft off the head (on the Poten'mtr side).
So, I popped off the broken Dog-Bone and its bits, welded the head back on the shaft and re-attached....job done
Thats main dealer service for you !
citroenxm
- Fallen Hero
- x 70
Stickyfinger wrote:WRONGdoubt VERY much we will ever get dog bone issues with ANY C5 models, Mk.1, 2 or X7 ...
WOW, is there really a need to shout! So how many hundreds of these have done this then compared to the rear linkage siezing on hundreds of xantia??????
Well done for getting it sorted though..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 1996
OK
The Dog-Bone on the X7 is very exposed...it will be getting my "creative" treatment to prevent more problems later.
Also, the alloy connectors on the fluid pipes have a fair amount on corrosion on them as well....very much worth checking and I for one
will be doing my nut in the dealers to get them replaced under the remaining warranty.
citroenxm
- Fallen Hero
- x 70
Stickyfinger wrote:OK
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
lexi
- x 133
Well it wasn't a bad fix. Preventative maintenance and clean/ lube for these then? You gonna make a sheild?
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
