Thank YOU Citroen for my pressie this morning
x 1995
Unread post by Stickyfinger »
A car that will not raise at the rear !....feck !
Not looked yet....but anything special to look for on the X7 C5 Tourer Exclusive....I am presuming grease the dog bone/ free the height adjuster ?
DickieG
Monaco's youngest playboy
x 33
Re: Thank YOU Citroen for my pressie this morning
Unread post by DickieG »
Have you tried using the manual height adjustment buttons?
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
vborovic
Locked user account
x 40
Unread post by vborovic »
I can't find the topic, but I recall someone having a similar problem, turned out it was one of the rear height connectors (or the wires from it) ... things like this make me happy that I'm on a regular suspension ... :) ... but I do share your concern as a fellow X7 owner
DHallworth
x 161
Unread post by DHallworth »
That's a right bugger on Christmas Day! The one day you hope the car will work without fault when you go to visit family!
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
x 1995
Going to take Mother to Church....teach me for not being a believer !
Rear boot buttons not working due to "fault" I expect
Front end goes full up and down all OK
Did a re-set....no change
Jumped on it....no change
Lexia not on new LapTop.....now it will not install !
|Feck this season to be Jolly
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
I doubt VERY much we will ever get dog bone issues with ANY C5 models, Mk.1, 2 or X7 ...
The rear height sensor is a Slack moving potentiometer, and will never suffer from sticky issues like the Xantias STUPID.. and I emphasise the STUPID too as it is the only model to have the complex stupid setup!
So, height - will be as above either a wire, or a dud height sensor at the back.
A very sad...
1994 XM 2.1 d auto
x 1995
Question, how to get under the bugger with its fat arse on the ground ?
citroenxm
Fallen Hero
x 70
Yea a good one that, short of backing up some home made ramps with planks and bricks to lift the rear up, not sure what else at the moment.... :?
A very sad...
1994 XM 2.1 d auto
x 1995
jacks, bricks, jacks, bricks, jacks, bricks, jacks, Axel stands :)
Richard_C
(Donor 2026)
x 233
Unread post by Richard_C »
A day late I know and hope you have it sorted by now.
You can sometimes get enought clearance to slither underneath a car by driving one side up onto as high a kerb as you can find, ideally not over a drain grid ....
Have you tried a total battery disconnect...cup of coffee....reconnect? Seem unlikely but might be worth a go.
Richard_C
x 1995
WRONG
Broken Dog-Bone Shaft....the ball on Potentiometer was seized as was the roll bar one, the pressure had shaped the metal dog-bone shaft off the head (on the Poten'mtr side).
So, I popped off the broken Dog-Bone and its bits, welded the head back on the shaft and re-attached....job done
Thats main dealer service for you !
citroenxm
Fallen Hero
x 70
WRONG
WOW, is there really a need to shout! So how many hundreds of these have done this then compared to the rear linkage siezing on hundreds of xantia??????
Well done for getting it sorted though..
A very sad...
1994 XM 2.1 d auto
x 1995
OK
The Dog-Bone on the X7 is very exposed...it will be getting my "creative" treatment to prevent more problems later.
Also, the alloy connectors on the fluid pipes have a fair amount on corrosion on them as well....very much worth checking and I for one
will be doing my nut in the dealers to get them replaced under the remaining warranty.
citroenxm
Fallen Hero
x 70
Stickyfinger wrote:OK
:-D
A very sad...
1994 XM 2.1 d auto
lexi
x 133
Unread post by lexi »
Well it wasn't a bad fix. Preventative maintenance and clean/ lube for these then? You gonna make a sheild?
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
