xantia 1995 19td, g box has gone v noisy i rebuilt it around 10 years ago at 120k now 0n 245k i think the main shaft bearings are shot again , i have been offered a box from a 1900td zx 1993 how can i tell whether it'll fit it looks the same but is it?
All help[ appreciated Tim
identifying g box type
if it aint broke fix it anyway
- My Cars: Citroens since 1990, BX Diesel, GTI, TZD with 1.9 TD running extra boost before it was fashionable!, ZX Volcane TD, S2 Xantia break 1.9TD, Xantia HDI 110, currently zipping about in a C2 Diesel. C2 died from the dreaded worm, C3 Picasso HDI Exclusive, the adventure continues.
- x 31
Re: identifying g box type
Probably, I have successfully transplanted gearboxes from a number of donors, a TD ZX should have a BE3 box.
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 70
It WILL be the same.
ALL TD equpit cars of this eira used the BE 3/5 box and they ALL used the pull clutch.
As long as the donar car be it ZX, 306 or 405 is DEAFENATLY a Turbo D 1.9.. then you be perfectly fine. No problem!
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Oh it's defiantly a 1900rd the injection pump from it is on my car and so are the injectors so as its gratis I will go and take it.out.
Incidentally does the be3suffer from diff problems
Tim
Tim
Not diff but more weak syncro on third gear.. ive not heard of diff issues. Im no expert though..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
The BE3 gearboxes on my previous BX DTR, & current Xantia TD, have exhibited weaker synchros on 2nd, rather than 3rd. On the TD, I find the slight crunch in 2nd occurs when the engine/gearbox oil is cold, the more so in winter IIRC. Will shortly find out over the next few months.
As regards using a gearbox from another model, I question whether the gear and diff ratios will be the same, although obviously as a system, it will still work. Sometime after my 1995 TD was built, the rev counter was changed (I won't say upgraded) from mechanical to electrical.
Martin
1995 Xantia TDLX (deceased )
TD rev counters have ALWAYS been electronic, and got their signal from a Black Sensor on the side of the Diff, and picked its signal from the back the of flywheel.
Ive not known of a mechanical rev counter on Xantia or 306/405 td's - unless Im mistaken.
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Oooops I think I mean the speedo take-off (not rev-counter) on output from the diff side of the gearbox - thanks Paul. Another senior momentcitroenxm wrote:Ive not known of a mechanical rev counter on Xantia or 306/405 td's - unless Im mistaken.
Martin
Lol no worries.. in fact it was earlyer then 1995.. it was in 1994 M reg they changed.. or is M reg 1995.. gawd i get so confused what letter is for what year..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
