pugeot 306 rear wheel tilting in at top help
stui b
- New User
Does any body know what might cause my rear driver side wheel to lean in at top the pass side is fine any help would be very apreciated
thanks guys
- x 94
Re: pugeot 306 rear wheel tilting in at top help
rear arm bush's failed, usual fix is find a good second hand rear axle and swap the hole thing over,
its best to find one like for like ie rear disc or drum brakes, there are various cit/pug models that use the same axle
Regards, malcolm.
- x 1240
If by chance you are in the west country there is a firm not far from here who will fit a recon axle while you wait - if you wait long enough.
addo
- Sara Watson's Stalker
- x 95
spider
- x 77
I think that's the problem, its getting it apart (not very nice, thankfully I've never had to, although seen plenty of others cursing) and back together again.
Andy.
- x 94
i havent done this job either, but i have heard story's of people who have attempted to repair these axles, saying on removing the trailing arm it had worn grooves into the cross tube, making it unusable/scrap
Regards, malcolm.
addo
- x 95
Welshy_Pete
There is also places that will repair and fit a rear beam on 306.
Once the wheels start tilting the bearing are shot.
addo
- x 95
stui b
- New User
thanks pal its disks on bak so think I'm gunna take your idea n get a back axle no point messin about with the bearinsPeter.N. wrote:If by chance you are in the west country there is a firm not far from here who will fit a recon axle while you wait - if you wait long enough.
addo
- x 95
Mountjoy Engineering, I think they're called. From memory £350 or so, fitted.
http://www.sspengineering.co.uk/" onclick="window.open(this.href);return false;
- x 1496
evilally
- x 3
I reconditioned a 405 beam a while back, £100 all in but it was a LOT of work:
'97 406 1.9TD, 314k.
JohnD
- x 72
Re:
addo wrote:Mountjoy Engineering, I think they're called. From memory £350 or so, fitted.
I took my daughter's Xsara to this guy in Devon. He did a cracking job. They recon the axle beams on site and will fit you a replacement in about 2.5 hours. They'll also send one out to you for the same price to fit DIY
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
stu9
- x 5
I think if that happans to mine, it'll get scrapped
