pugeot 306 rear wheel tilting in at top help
stui b
New User
Unread post by stui b »
Does any body know what might cause my rear driver side wheel to lean in at top the pass side is fine any help would be very apreciated :) thanks guys
x 94
Re: pugeot 306 rear wheel tilting in at top help
Unread post by citronut »
rear arm bush's failed, usual fix is find a good second hand rear axle and swap the hole thing over,
its best to find one like for like ie rear disc or drum brakes, there are various cit/pug models that use the same axle
Regards, malcolm.
x 1238
Unread post by Peter.N. »
If by chance you are in the west country there is a firm not far from here who will fit a recon axle while you wait - if you wait long enough.
addo
Sara Watson's Stalker
x 95
Unread post by addo »
You can buy new pivot pins for £23 each and new bearing sets for £22 per side. Removal of the beam assembly is necessary for the repair.
spider
x 77
Unread post by spider »
I think that's the problem, its getting it apart (not very nice, thankfully I've never had to, although seen plenty of others cursing) and back together again.
Andy.
x 94
i havent done this job either, but i have heard story's of people who have attempted to repair these axles, saying on removing the trailing arm it had worn grooves into the cross tube, making it unusable/scrap
Regards, malcolm.
addo
x 95
That can happen, one bodge is to relocate the bearings slightly.
Welshy_Pete
Unread post by Welshy_Pete »
There is also places that will repair and fit a rear beam on 306.
Once the wheels start tilting the bearing are shot.
addo
x 95
They charge a fair whack, though, and you're nearly as tight with money as I am.
Provided you can get the old bearings out and have someone press the new stubs onto your shafts, it's four Haynes spanner territory.
stui b
New User
Peter.N. wrote:If by chance you are in the west country there is a firm not far from here who will fit a recon axle while you wait - if you wait long enough.
thanks pal its disks on bak so think I'm gunna take your idea n get a back axle no point messin about with the bearins
:-D while I'm on u dnt no what the best way to adjust the clutch cabe its a auto adjust mine snaped so put a new 1 on but its hard 2 get in gear now ](*,) thanks
addo
x 95
Mountjoy Engineering, I think they're called. From memory £350 or so, fitted.
http://www.sspengineering.co.uk/" onclick="window.open(this.href);return false;
x 1431
http://www.detailingworld.co.uk/forum/s ... p?t=288941
£350 fitted looks like a bargain to me!!
evilally
x 3
Unread post by evilally »
I reconditioned a 405 beam a while back, £100 all in but it was a LOT of work:
'96 405 1.6 GLX with 306 GTI engine on Cat cams @ 195bhp
'05 RenaultSport Clio 182 Cup, 102k
'97 406 1.9TD, 314k.
JohnD
(Donor 2022)
x 72
Re:
Unread post by JohnD »
addo wrote:Mountjoy Engineering, I think they're called. From memory £350 or so, fitted.
I took my daughter's Xsara to this guy in Devon. He did a cracking job. They recon the axle beams on site and will fit you a replacement in about 2.5 hours. They'll also send one out to you for the same price to fit DIY
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
stu9
x 8
Unread post by stu9 »
I think if that happans to mine, it'll get scrapped
