Go on, I give up...
How do you remove the wireless from a very late S2 Xantia with the flip-up cover?
I see four holes around the edge of the wireless so I guess I need some form of special tool for this... Poking various round things down the holes does not produce the desired result...
Thanks!
Late S2 Xantia Wireless Removal?
- x 8457
Gingerposer
- x 6
Re: Late S2 Xantia Wireless Removal?
Visit your local motor factor, tell them you need stereo removal keys - they will be able to tell you what kind you need for the particular stereo, should only cost you a couple of beer tokens.
fastred
I have a pair of the proper tools you can have, Jim. pm me your address and I will slip them in the post
fastred
fastred
- x 8457
That's most kind fastred...fastred wrote:I have a pair of the proper tools you can have, Jim. pm me your address and I will slip them in the post
I shall do just that
That is very appreciated
DickieG
- Monaco's youngest playboy
- x 33
Get a wire coat hanger, cut off two lengths of about 6" and bend each one to shape for the holes (one each side), works for me.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
deuchebleu
- x 21
I just used to use a small electrical screwdriver.
Push it in the hole and pull the radio fascia to release one catch and whilst still pulling take it out and stick it in the other hole.
Once you get it out it's easy to see what you're trying to do. It's basically a leaf spring that you just push to one side.
John
John
addo
- Sara Watson's Stalker
- x 95
citroenxm
- Fallen Hero
- x 70
NONE Of the Above Jim...
Have the flap in LOW position, flip off the Outer edge TRIM around the radio itself with a flat blade screw driver...
Behind there, 4x torx T20 Screws, two top , two bottom then the WHOLE lot comes away..!!
Simples!
Paul
Simples!
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 8457
Fastred, they arrived today and work absolutely perfectly. Many thanks indeedfastred wrote:I have a pair of the proper tools you can have, Jim. pm me your address and I will slip them in the post
Paul, now with the surround clipped off (it wouldn't until the wireless itself was pulled slightly forward using the keys) all is now clear...
Thanks all
Jaf
- x 42
My but I'm jealous of your postage system! And pie shops....cake shops...B&Q....
Fred, a silver 1998 1.9TD SX Xantia.
Gwin, a white 1994 1.1 AX.
