Late S2 Xantia Wireless Removal?
x 8082
Go on, I give up...
How do you remove the wireless from a very late S2 Xantia with the flip-up cover?
I see four holes around the edge of the wireless so I guess I need some form of special tool for this... Poking various round things down the holes does not produce the desired result...
Thanks!
Gingerposer
x 6
Re: Late S2 Xantia Wireless Removal?
Unread post by Gingerposer »
Visit your local motor factor, tell them you need stereo removal keys - they will be able to tell you what kind you need for the particular stereo, should only cost you a couple of beer tokens.
fastred
Unread post by fastred »
I have a pair of the proper tools you can have, Jim. pm me your address and I will slip them in the post
fastred
x 8082
fastred wrote:I have a pair of the proper tools you can have, Jim. pm me your address and I will slip them in the post
That's most kind fastred...
I shall do just that :-D And return them as soon as I've done with them..
That is very appreciated :-D
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
Get a wire coat hanger, cut off two lengths of about 6" and bend each one to shape for the holes (one each side), works for me.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
deuchebleu
x 20
Unread post by deuchebleu »
I just used to use a small electrical screwdriver.
Push it in the hole and pull the radio fascia to release one catch and whilst still pulling take it out and stick it in the other hole.
Once you get it out it's easy to see what you're trying to do. It's basically a leaf spring that you just push to one side.
John
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Würth sell a tool that is quite neat. It splits in two, one side being a mirror of t'other. Rather like a Victorinox knife, you fold out the corresponding tool "prongs" on each part, then insert and ease out the radio.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
NONE Of the Above Jim...
Have the flap in LOW position, flip off the Outer edge TRIM around the radio itself with a flat blade screw driver...
Behind there, 4x torx T20 Screws, two top , two bottom then the WHOLE lot comes away..!! =D> #-o
Simples!
Paul
A very sad...
1994 XM 2.1 d auto
x 8082
Fastred, they arrived today and work absolutely perfectly. Many thanks indeed :-D
Paul, now with the surround clipped off (it wouldn't until the wireless itself was pulled slightly forward using the keys) all is now clear...
Thanks all :-D
Jaf
x 42
Unread post by Jaf »
My but I'm jealous of your postage system! And pie shops....cake shops...B&Q....
Fred, a silver 1998 1.9TD SX Xantia.
Gwin, a white 1994 1.1 AX.
