Green Spring
HFF
Green Spring
Any idea what the small green spring does which is attached to what looks a break pipe manifold on the rear axle.
- x 5667
andmcit
- x 30
addo
- Sara Watson's Stalker
- x 95
- x 94
HFF
Thanks Guys
Thanks all.
Yes will get to it will Plusgas and mole grips, must wait untill the 2 feet of snow clears first
HFF
How much movement
Any idea how much movement I shouls see if it is free to move.
It looks as if the lever bit is seized in the closed position as there is a gap of about 10mm between the lever and the underside of the adjusting bolt head.
- x 94
