Green Spring
HFF
Green Spring
Unread post by HFF »
Any idea what the small green spring does which is attached to what looks a break pipe manifold on the rear axle.
x 5671
What vehicle is it attached to?
HFF
Berlingo
I think it is the brake pressure regulating valve that the spring is attached to, however the arm of the valve apears to have siezed as ir does not move, any ideas how to free it?
andmcit
x 30
Unread post by andmcit »
Steve, I know where you're coming from but curiosity got the better
of me and I checked out the poster's other posts = bingo Berlingo!!
:roll:
Andrew
addo
Sara Watson's Stalker
x 95
Unread post by addo »
They generally don't move much.
Before condemning it, maybe fondle a new one and see if the regulation lever has any more travel.
x 94
Unread post by citronut »
if it has seized it is usualy at the arm pivot poit, which if you lub and work lub and work lub and work it a few times it will free off,
regards malcolm
HFF
Thanks Guys
Thanks all.
Yes will get to it will Plusgas and mole grips, must wait untill the 2 feet of snow clears first :D
HFF
How much movement
Any idea how much movement I shouls see if it is free to move.
It looks as if the lever bit is seized in the closed position as there is a gap of about 10mm between the lever and the underside of the adjusting bolt head.
x 94
just make sure it is moveing freely, and returns to rest on its own,
these dont move very far at all in normal use this is why the seize up,
but once free you will be able to move it by hane further than it does in normal use,
regards malcolm
