Good Morning all,
I thought I would let you all know the old girl passed her MOT again
I had the welding done by a very good mechanic who restores vintage cars as a hobby. You would hardly notice the weld.
3 Advisorys which were on the list to fix anyway.
The emisson test was good both times 0.31 and 0.39 m-1 so it would suggest that all my pump woes are not as bad.
Kenny
Xantia Mot- success
KennyW
- x 165
Xantia Mot- success
C3 1.4 petrol (SWMBO)
- x 8470
KennyW
- x 165
Jim,
It was below the rear nearside passenger door. I posted photo's on somebody's posting about the same subject rusting sills.
Kenny
Kenny
- x 8470
- x 1507
Good work Kenny!
Pics here: Kenny's rust
That's not the usual spot - which is higher up in the door jamb.....where I see my estate is starting to show signs
I wonder if there is a better solution to the wheelarch 'sealing' to help put it off??
- x 8470
brmartyn
My Xantia past its MOT at the beginning of the month and all it needed was rear brake pads. Thanks to Jim for his hard work prior to the MOT.
Brady
Citroen C8 2.2 HDI Exclusive 2006/06
Previous French cars -
Renault Megane Tourer 2004/54 1.9 DCI Privilege
Citroen Xantia 1998/S 2.0 16v Exclusive Automatic
Renault Laguna Sports Tourer Dymanique 2001/51
Citroen Saxo VTR 2000/W
- x 8470
KennyW
- x 165
Hi All,
I think the water found its way in via the wheel arch and ran down into the sill.
The usual seal problem 'underneath the arches' is that not a song or famous farmers program
Kenny[/b]
Kenny[/b]
