Xantia Mot- success
KennyW
x 165
Xantia Mot- success
Unread post by KennyW »
Good Morning all,
I thought I would let you all know the old girl passed her MOT again
I had the welding done by a very good mechanic who restores vintage cars as a hobby. You would hardly notice the weld.
3 Advisorys which were on the list to fix anyway.
The emisson test was good both times 0.31 and 0.39 m-1 so it would suggest that all my pump woes are not as bad.
Kenny
C3 1.4 petrol (SWMBO)
x 8363
Kenny,
That's brilliant news :D :D
Where did she need welding?
I'm sure you've told us in the past but old age and all that :roll: You know...
KennyW
x 165
Jim,
It was below the rear nearside passenger door. I posted photo's on somebody's posting about the same subject rusting sills.
Kenny
x 8363
Thanks Kenny,
Rust in the usual place then :twisted:
x 1485
Good work Kenny!
Pics here: Kenny's rust
That's not the usual spot - which is higher up in the door jamb.....where I see my estate is starting to show signs :cry: I wonder if there is a better solution to the wheelarch 'sealing' to help put it off??
x 8363
Thanks for finding the pictures Richard, you really are the forum search-engine :D
brmartyn
Unread post by brmartyn »
My Xantia past its MOT at the beginning of the month and all it needed was rear brake pads. Thanks to Jim for his hard work prior to the MOT. :D :D :D :D :D :D :D
Brady
Citroen C8 2.2 HDI Exclusive 2006/06
Previous French cars -
Renault Megane Tourer 2004/54 1.9 DCI Privilege
Citroen Xantia 1998/S 2.0 16v Exclusive Automatic
Renault Laguna Sports Tourer Dymanique 2001/51
Citroen Saxo VTR 2000/W
x 8363
brmartyn wrote:My Xantia past its MOT at the beginning of the month and all it needed was rear brake pads. Thanks to Jim for his hard work prior to the MOT. :D :D :D :D :D :D :D
Brilliant news Brady :D :D :D
KennyW
x 165
Hi All,
I think the water found its way in via the wheel arch and ran down into the sill.
The usual seal problem 'underneath the arches' is that not a song or famous farmers program :wink:
Kenny[/b]
