Xantia V6 Cutting out and Starting Problems
DHallworth
- x 161
Our Xantia V6 seems to be giving problems at the moment.
It started to be hesitant and snatching when moving off until I changed the fuel filter and that seemed to cure that, guess it was just being starved of Petrol.
Now it seems to be cutting out, the revs fluctuate to suit it's temperament and when it's remotely warm, even after running for 2 minutes it seems to refuse to start.
Tonight I just managed to coax it into starting, and when it did start it seemed like there was a plume of grey smoke from it. I ran the Lexia on it and it told me there was a temperature sensor giving a bad reading.
Only problem is it didn't tell me which one it was likely to be. Instinct tells me it's likely to be the brown sensor, is this the one that talks to the Bitron box?
Thanks in advance guys.
David.
David.
'98 Xantia Activa V6
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
- x 1471
It won't be the brown (bitron) sensor, as that only affects the cooling fans and A/C. The engine ECU uses the green sensor (I think). A faulty temperature sensor can cause very poor running.
I don't think that either of them are easy to get at. I think that the Lexia actually tells you the temperature measured by the green sensor, so you should be able to get a "second opinion".
Was the sensor fault current, or just a stored fault?
DHallworth
- x 161
From memory without going and checking again, I think the temperature sensor was reading a constant 30 degrees.xantia_v6 wrote:It won't be the brown (bitron) sensor, as that only affects the cooling fans and A/C. The engine ECU uses the green sensor (I think). A faulty temperature sensor can cause very poor running.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
- x 8422
The Green (ECU) sensor is easy enough to get to. It's the brown Bitron that's a pain..
This pic shows it, just below the lower green arrow... The original picture was done to show the bleed valve locations.
Don't forget there is also a temperature sensor on the airbox by the idle air hose...
30 degrees F or C?
30 degrees F or C?
- x 1471
DHallworth
- x 161
- x 8422
DHallworth
- x 161
citroenxm
- Fallen Hero
- x 70
hmm I wonder if this is whats causing a missfire when cold on my V6... once warmed through shes perfect through the rev range, so I cant see it being coil packs, also has new plugs...
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 8422
citroenxm
- Fallen Hero
- x 70
No, which sensor then Jim???
Time to play the guess game, OR have you a set of known good ones I can plonk in when shes next on the repair list..??
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 8422
DHallworth
- x 161
Brilliant, Thanks Jim, I'll check this one tonight.CitroJim wrote:Lexiacitroenxm wrote:No, which sensor then Jim???You have one haven't you Paul?
David, green sensor reads 2.9K at 21 Degrees...
A new one from Cit is £31.
I'll warm it up and cool it down and see if I can get a different reading from it. If I can then I'm guessing it's another wiring fault like the heater on this blasted HDi.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
MikeT
- x 232
DHallworth
- x 161
I do indeed...MikeT wrote: I just replaced mine on the 1.9TD but it was about 2/3 that price. Do you know the part number? It's possible they're the very same part.
Part number given to me by Citroen Glasgow was 133891.
I should also say it was £31 + VAT so will be about £38.
Are they the same between Petrols & Diesels?
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
